Go to Post I think your robot is lacking in non-threatening, huggable design. - Kevin Sevcik [more]
Unread 08-12-2010, 12:23
austinious austinious is offline
FRC #3567
austinious is an unknown quantity at this point
Using JCreator instead of NetBeans
Rookie Team 3567 Here
I used to use NetBeans before they changed way back when to be more like Eclipse, cumbersome.
I switched to JCreator LE which is a nice simple compiler. I've searched but there is almost no info on using anything other than NetBeans.
Has anyone figured out how to use a IDE other than Eclipse or NetBeans?
Unread 11-12-2010, 19:13
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Using JCreator instead of NetBeans
I haven't tried that, but i did a similar thing with BEST. I made netbeans compatible with the easyC compilers. See if you can find the sunspotfrcjdk and point Jcreator to that directory for the compiling tools.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
using an IDE other than NetBeans for Java isaacdl Programming 12 14-06-2010 22:42
Gyro instead of GTS windell747 Electrical 3 13-02-2008 08:22
Has anyone keyed IFI wheels instead of using the bearings? Dasistmeinmoped Technical Discussion 3 24-01-2007 00:03
SERAL INSTEAD OF DEBUG... EGG0900 Programming 2 05-11-2005 18:25
Instead of Castors .... shyra1353 General Forum 4 20-02-2004 14:29
