Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
  #46   Spotlight this post!
Unread 12-12-2010, 03:42
Re: Grey Jaguar No Power Out
Originally Posted by kamocat View Post
80 watts IS a lot, isn't it?
I wonder why infineon claims each power transistor can dissipate 100 Watts?
That spec only accounts for the junction to case thermal resistance and assumes a perfect heatsink with infinite mass at 25C. Power MOSFET specs are actually pretty funny when you look into the assumptions made.
I'm still confused as to what is going on. How is this different than the ESD issue?
  #47   Spotlight this post!
Unread 13-12-2010, 00:43
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
How is the "no power out" different from the ESD issue?
Did I miss something?
In order for ESD to be a problem, wouldn't the case have to be opened up. You're saying the case was opened up while the Jaguar was still functional? Why would someone do that?
Or is it something else entirely?
-- Marshal Horn
  #48   Spotlight this post!
Unread 13-12-2010, 07:59
Marshal,
The ESD issue didn't need the case to be open. During the 2009 game, the regolith especially in ice arenas produced some rather extensive static lightning strikes for robots and field. Some of these events punched through the case or traveled along the wiring and took out some components. The early Jags also had an issue with the FET gate drivers that would self destruct and usually caused a single direction failure.
  #49   Spotlight this post!
Unread 13-12-2010, 17:10
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Marshal,
Does that mean I can return it for replacement?
-- Marshal Horn
  #50   Spotlight this post!
Unread 13-12-2010, 18:54
I would recommend that you read the Jaguar Failure Analysis (FA) report, and then at least attempt an RMA. Both are linked from the luminary micro jaguar FRC site. Your Jaguar is probably out of warranty, but it doesn't hurt to try, and at least lets TI know the extent of the problems.
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
Power out puts ErinColleen Technical Discussion 2 21-01-2005 14:19
Grey Foam-Rubber Wheels RBrandy Technical Discussion 3 31-10-2003 01:11
Grey Daze Raven_Writer Chit-Chat 0 24-08-2003 18:45
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
