| Thread Tools |
Rating:
Display Modes |
NetBeans download error: StackOverflowError
I was attempting to play with java, but when I click the play arrow to run the code on the robot, it produces this output:
init:
init:
No to.jar.file specified.
Using "suite\RobotTemplate2_1.0.0.jar"
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\build
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\suite
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\j2meclasses
clean:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\build
Compiling 9 source files to C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\build
compile:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\j2meclasses
preverify:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\suite
Building jar: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\suite\RobotTemplate2_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
Exception in thread "main" java.lang.StackOverflowError
at java.io.InputStream.<init>(InputStream.java:28)
at java.io.FileInputStream.<init>(FileInputStream.java:96)
at com.sun.squawk.io.j2se.file.Protocol.open(Protocol.java:109)
at javax.microedition.io.Connector.openPrim(Connector.java:308)
at javax.microedition.io.Connector.open(Connector.java:234)
at javax.microedition.io.Connector.open(Connector.java:195)
at javax.microedition.io.Connector.openDataInputStream(Connector.java:340)
at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:196)
at com.sun.squawk.ObjectMemoryLoader.loadParent(ObjectMemoryLoader.java:538)
at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:339)
at com.sun.squawk.ObjectMemoryLoader.load0(ObjectMemoryLoader.java:255)
at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:170)
at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:197)
C:\Documents and Settings\***\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Documents and Settings\***\sunspotfrcsdk\ant\suite.xml:54: Java returned: 1
BUILD FAILED (total time: 1 minute 50 seconds)
I have encountered this on NetBeans 6.7.1 & 6.9.1, I have the first plugins installed, and I have set my team number. Is there anything else I must do? |
Re: NetBeans download error: StackOverflowError
Did this happen the first time you tried uploading code?
Is the NetBeans Project set properly? Have you tried running the code on another computer? It's an interesting place for a stack overflow to occur. It doesn't seem likely that a problem with the code could cause this error, but have you checked for infinite loops? |
2. I have no idea, I created a new project from the simplerobottemplate 3. no 4. no, it compiles file, but when I click the green arrow it spews this out. |
Unless your user account is really "\***\", I'm not sure what's going on. Have you tried a " clean and build"?
In NetBeans, right-click on the project (in the upper-left P"Projects" pane), and select "Clean and Build".
#7
nope, not seeming to work, I still get the stack overflow |
#8
I've managed to set the verbosity higher, and this is the command its choking on
I tried running this on a different computer, and it worked, so it must be this computer. Does the JDK version matter? I had to do a fresh install of JDK 23 on the other computer, so I looked at the JDk version on my computer, and it is 22. not sure if it makes a difference, but I tried updating and it failed.
| FRC Netbeans Template | RoboElite640 | Technical Discussion | 7 | 11-15-2010 09:57 AM |
| NetBeans Debugging | wrepavich | Java | 1 | 02-09-2010 07:14 AM |
| Program C++ in NetBeans? | camper365 | Programming | 7 | 01-17-2010 10:12 PM |
| [Windriver] Getting error on run: Download Failed | JHale | C/C++ | 4 | 01-15-2009 07:42 AM |
| RC Error: Bad Download!? | The Lucas | Electrical | 3 | 04-28-2003 07:45 AM |
