Go to Post For FIRST robots, the phenomena listed above just do not apply. - Paul Copioli [more]
Unread 13-12-2010, 00:43
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Grey Jaguar No Power Out
Originally Posted by EricVanWyk View Post
I'm still confused as to what is going on. How is this different than the ESD issue?
How is the "no power out" different from the ESD issue?
Did I miss something?
In order for ESD to be a problem, wouldn't the case have to be opened up. You're saying the case was opened up while the Jaguar was still functional? Why would someone do that?
Or is it something else entirely?
-- Marshal Horn
Unread 13-12-2010, 07:59
Marshal,
The ESD issue didn't need the case to be open. During the 2009 game, the regolith especially in ice arenas produced some rather extensive static lightning strikes for robots and field. Some of these events punched through the case or traveled along the wiring and took out some components. The early Jags also had an issue with the FET gate drivers that would self destruct and usually caused a single direction failure.
Unread 13-12-2010, 17:10
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Marshal,
Does that mean I can return it for replacement?
-- Marshal Horn
Unread 13-12-2010, 18:54
I would recommend that you read the Jaguar Failure Analysis (FA) report, and then at least attempt an RMA. Both are linked from the luminary micro jaguar FRC site. Your Jaguar is probably out of warranty, but it doesn't hurt to try, and at least lets TI know the extent of the problems.
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
Power out puts ErinColleen Technical Discussion 2 21-01-2005 14:19
Grey Foam-Rubber Wheels RBrandy Technical Discussion 3 31-10-2003 01:11
Grey Daze Raven_Writer Chit-Chat 0 24-08-2003 18:45
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
