Go to Post You can't just leave us hanging! That was SOOO 2010! - nighterfighter [more]
Unread 12-12-2010, 10:49
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
NetBeans download error: StackOverflowError
I was attempting to play with java, but when I click the play arrow to run the code on the robot, it produces this output:
init:
init:
No to.jar.file specified.
Using "suite\RobotTemplate2_1.0.0.jar"
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\build
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\suite
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\j2meclasses
clean:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\build
Compiling 9 source files to C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\build
compile:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\j2meclasses
preverify:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\suite
Building jar: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate2\suite\RobotTemplate2_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
Exception in thread "main" java.lang.StackOverflowError
        at java.io.InputStream.<init>(InputStream.java:28)
        at java.io.FileInputStream.<init>(FileInputStream.java:96)
        at com.sun.squawk.io.j2se.file.Protocol.open(Protocol.java:109)
        at javax.microedition.io.Connector.openPrim(Connector.java:308)
        at javax.microedition.io.Connector.open(Connector.java:234)
        at javax.microedition.io.Connector.open(Connector.java:195)
        at javax.microedition.io.Connector.openDataInputStream(Connector.java:340)
        at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:196)
        at com.sun.squawk.ObjectMemoryLoader.loadParent(ObjectMemoryLoader.java:538)
        at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:339)
        at com.sun.squawk.ObjectMemoryLoader.load0(ObjectMemoryLoader.java:255)
        at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:170)
        at com.sun.squawk.ObjectMemoryLoader.load(ObjectMemoryLoader.java:197)
C:\Documents and Settings\***\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Documents and Settings\***\sunspotfrcsdk\ant\suite.xml:54: Java returned: 1
BUILD FAILED (total time: 1 minute 50 seconds)
And I am unable to run code on the cRIO.
I have encountered this on NetBeans 6.7.1 & 6.9.1, I have the first plugins installed, and I have set my team number. Is there anything else I must do?
Watchdog.Kill();
Unread 12-12-2010, 22:32
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: NetBeans download error: StackOverflowError
Did this happen the first time you tried uploading code?
Is the NetBeans Project set properly?
Have you tried running the code on another computer?
It's an interesting place for a stack overflow to occur. It doesn't seem likely that a problem with the code could cause this error, but have you checked for infinite loops?
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 13-12-2010, 08:42
byteit101's Avatar
1. yes, and the first time i used netbeans for anything other than autocomplete
2. I have no idea, I created a new project from the simplerobottemplate
3. no
4. no, it compiles file, but when I click the green arrow it spews this out.
Watchdog.Kill();
Unread 16-12-2010, 00:02
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Unless your user account is really "\***\", I'm not sure what's going on. Have you tried a " clean and build"?
Unread 16-12-2010, 14:41
byteit101's Avatar
how would I do that?
Watchdog.Kill();
Unread 17-12-2010, 16:58
derekwhite's Avatar
In NetBeans, right-click on the project (in the upper-left P"Projects" pane), and select "Clean and Build".
Unread 17-12-2010, 17:37
byteit101's Avatar
ah, duh.
nope, not seeming to work, I still get the stack overflow
Watchdog.Kill();
Unread 17-12-2010, 20:05
byteit101's Avatar
I've managed to set the verbosity higher, and this is the command its choking on
Executing 'C:\Program Files\Java\jdk1.6.0_21\jre\bin\java.exe' with arguments:
'-XX:CompileCommand=exclude,com/sun/squawk/Method.getParameterTypes'
'-XX:CompileCommand=exclude,com/sun/squawk/SymbolParser.getSignatureTypeAt'
'-XX:CompileCommand=exclude,com/sun/squawk/SymbolParser.stripMethods'
'-Xmx256M'
'-classpath'
'C:\Documents and Settings\***\sunspotfrcsdk\bin\romizer_classes.jar ;C:\Documents and Settings\***\sunspotfrcsdk\bin\squawk.jar;C:\Docum ents and Settings\***\sunspotfrcsdk\bin\squawk_device_class es.jar;C:\Documents and Settings\***\sunspotfrcsdk\bin\translator_classes. jar'
'com.sun.squawk.Romizer'
'-nobuildproperties'
'-suitepath:C:/Documents and Settings/***/sunspotfrcsdk/cRIO'
'-boot:squawk'
'-metadata'
'-lnt'
'-strip:d'
'-cp:suite\BuiltInDefaultCode_1.0.0.jar'
'-endian:big'
'-o:image'
'suite\BuiltInDefaultCode_1.0.0.jar'
The ' characters around the executable and arguments are
not part of the command.
at java.io.FileInputStream.<init>(FileInputStream.jav a:96)
at com.sun.squawk.io.j2se.file.Protocol.open(Protocol .java:109)
at javax.microedition.io.Connector.openPrim(Connector .java:308)
Watchdog.Kill();
Unread 27-12-2010, 15:01
byteit101's Avatar
I tried running this on a different computer, and it worked, so it must be this computer. Does the JDK version matter? I had to do a fresh install of JDK 23 on the other computer, so I looked at the JDk version on my computer, and it is 22. not sure if it makes a difference, but I tried updating and it failed.
Watchdog.Kill();
FRC Netbeans Template RoboElite640 Technical Discussion 7 15-11-2010 09:57
NetBeans Debugging wrepavich Java 1 09-02-2010 07:14
Program C++ in NetBeans? camper365 Programming 7 17-01-2010 22:12
[Windriver] Getting error on run: Download Failed JHale C/C++ 4 15-01-2009 07:42
RC Error: Bad Download!? The Lucas Electrical 3 28-04-2003 07:45
