Go to Post It's only messy if you allow it to be. - Jay H 237 [more]
Unread 14-12-2010, 16:11
Re: HELP with TANK DRIVE PROGRAMMING
Stay on topic or start a new thread. This cocktail party isn't helping the original poster...
Originally Posted by dcarswell View Post
Are than any steps you can give me or a help guide that is in labview that will show me how to divide functions?
Here's an example for a single motor of what Ether is suggesting.
The 0.25 constant is the percentage of max power.
For tank drive you'd multiply both speed inputs to the Tank Drive vi.
You can also replace that fixed constant with an input from the throttle to make your power adjustable, so you can change it on-the-fly until you get the value you feel is right.
P.S.
Not that you've said you have this issue, but if turning at low power is a problem with your robot you can also do something in software that doesn't require adding sensors, physically changing the gearing, or swapping out sticky wheels for slicks.
In your code you can avoid applying the power reduction to any turning component or make just turning a higher percentage. For example, if one of your joysticks is forward and the other is backward, then don't reduce the power to the joysticks. If they are both forward but to varying degrees, so you get a curved driving path, then leave the difference between the sticks alone and only reduce the straight component.
ID:	9496  Click image for larger version
Need help with tank drive nickcvet89 NI LabVIEW 16 02-02-2010 16:35
Problem with tank drive Mr. E NI LabVIEW 6 27-01-2009 16:59
Help with programing Tank Drive in Lab View zackcool123 NI LabVIEW 3 18-01-2009 19:49
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
Tank Drive help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Idaman323 Programming 3 18-02-2005 15:17
