Go to Post Just think of the deadline as your six week deadline for FIRST, just when you think you can't do it, you are amazed by what you can do. - JackN [more]
Unread 14-12-2010, 17:01
Red987 Red987 is offline
FRC #0987
Red987 is an unknown quantity at this point
[FTC]: Issues adding 3rd servo
ok so i have 2 servos working, but when i try to add a 3rd, all the servos stop working completely, but i can still drive the robot. When i push the buttons for the servos, the drive terrain starts moving. I have posted the code and could really use some help with getting all the servos to work.
Unread 14-12-2010, 17:27
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
Re: [FTC]: Issues adding 3rd servo
I believe you have a problem with your motor and servo configurations. Both your motor controller and servo controller seem to be configured to be the first in the daisy chain.
Unread 14-12-2010, 21:38
PSHRobotics PSHRobotics is offline
FRC #1182
PSHRobotics is an unknown quantity at this point
It would be really helpful if you could post your motor configuration and servo configuration files. And the program with 2 servos working.
I would also recommend not using two joystick reads for the same controller. Though I haven't seen it ruin a program, I have seen it increase the possibility of logic problems.
Also, when teleop is offline or the main loop is "False" you are using the template motor configurations to stop the robot. What would be more common to do is use the configuration file you are using to actually move the robot and also use it to stop the robot.
Other than those details, which shouldn't break the code, the actual code for the servo looks correct so I suspect something is wrong in either wiring or in the configurations.
[FTC]: Samantha issues at VCU FRC/FTC workshops - how to fix cybiko123 FIRST Tech Challenge 3 13-12-2010 13:18
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 26-01-2009 21:25
[FTC]: Servo Reversing? teamN20 FIRST Tech Challenge 0 26-11-2008 14:17
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
Servo Controller Power Issues.... John Gutmann Electrical 8 09-04-2007 01:31
