Go to Post You can't lose if you submit an animation. Even if you don't win an award, your team wins by just doing it. - David Brinza [more]
Unread 14-12-2010, 16:09
mprikril mprikril is offline
FRC #0056 (R.O.B.B.E.)
mprikril is a jewel in the roughmprikril is a jewel in the roughmprikril is a jewel in the rough
Wireless Set Up Problem
We are trying to set up a prototype using a new cRIO but with our old wireless router and bridge and are running into an interesting problem.
With the IP address of the PC set to 10.0.56.10, I plug the PC into the router and if I browse for 10.0.56.4, I can see the router set-up (with the correct settings)
If I plug the PC directly into the wireless bridge and browse to 10.0.56.1, I can see the bridge set-up (with the correct settings)
However, if I plug the PC into the router with no connection to the bridge, I can not see the Bridge
Any ideas on what's wrong here? thanks
Unread 14-12-2010, 16:13
bscharles's Avatar
bscharles bscharles is offline
Booyah
AKA: Brian Scharles
FRC #0930 (The Mukwonago BEARs)
bscharles will become famous soon enough
Re: Wireless Set Up Problem
is the bridge correctly connected wirelessly to the router?
Unread 14-12-2010, 16:21
Have you checked the WGA encryption (read: is the encryption of the bridge off)?
Unread 14-12-2010, 16:29
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
also, make sure the router's settings are correct (should be on FIRST's website under control system documentation)
Unread 14-12-2010, 17:49
Are we to infer from the above that you can see the bridge when the PC is plugged into the router if the bridge is wired to the router? You didn't state this explicitly but it seems to be implied.
Unread 14-12-2010, 21:15
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
If you haven't reset the bridge since your last event, it could still be set up to work through FMS instead of directly from the wireless router
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 14-12-2010, 21:36
Ah yes, the WPA encryption at the Regional events. I forgot about that.
We'll give that a shot.
Thanks, you guys are awesome
Unread 15-12-2010, 17:16
plnyyanks's Avatar
AKA: Phil Lopreiato
here's some instructions I made for my team in reseting the gaming adapter (in case you need them)
Unread 14-01-2011, 21:10
BenGrapevine's Avatar
BenGrapevine BenGrapevine is offline
Head Programmer
AKA: Tony Simmering
FRC #2549 (Millerbots)
BenGrapevine is an unknown quantity at this point
My team is having a wierd problem with the robot from last year, the bridge doesn't seem to be able to connect to the router. The router and the classmate are hooked up and working fine, but the bridge is not. Does that mean that we need a new bridge?
Millerbots Team 2549
orange and blue
Unread 14-01-2011, 21:25
I don't think so. Check the encryption mentioned earlier. If it's on, turn it off.
Unread 18-01-2011, 13:56
koepke92 koepke92 is offline
FRC #3862
koepke92 is an unknown quantity at this point
We are having the same problem with a D-link router we can access the router via ip address. But once ethernet cable is unplugged we can not pick up the signal please email me or post here if you have any suggestions.
Also failed to mention we are using the rookie set-up
Unread 18-01-2011, 14:13
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I was working at a Rookie workshop this weekend and we discovered that the new routers default to 5ghz instead of 2.4ghz. Go into the wireless settings of the router (make sure you are using Internet explorer and not another browser) and change it to enable 802.11b and g. That should allow you to see your team's SSID.
Also refer to this manual for help Manual
Wireless problem bladetech932 FRC Control System 10 20-07-2010 16:44
Unable to set up wireless CeciliaC Programming 4 28-02-2010 16:32
Wireless Connection Problem Matt2081 Control System 16 21-02-2010 13:59
Wireless Connection Problem!!! EagleS!! General Forum 5 28-01-2010 07:56
Wireless Connection Problem jaustin FRC Control System 18 18-01-2009 13:41
