Go to Post Nothing motivates people to join like the promise of a trip to far-away lands of regional/championship competition during school days :) - Joe G. [more]
Unread 15-12-2010, 17:57
Generator of Entropy
FRC #2973 (The Mad Rockers)
Warming up the batteries
I'm definitely not used to this problem, being a 5th generation Floridian. We have retrofitted last year's robot to put a shovel in the ground and dig some dirt for the Ceremonial groundbreaking of a new high school in our team's school district tomorrow morning. We did a test run yesterday and everything worked fine, except that the driver said it seemed to be running very slow. I checked the voltage of the freshly charged battery and it showed under 12V no load. Oh by the way, it was 17 degrees F outside when we made the test run, and although the batteries had been stored inside the school I had them in the back of the pickup for the half hour drive to the site.
It's supposed to be up to about 50F tomorrow morning; If we warm up a fresh battery overnight and keep it warm until just before the big show, is it going to be good sitting for an hour during the speeches or do I need to wait until right before we power up to change it out?
Unread 15-12-2010, 18:02
ATannahill ATannahill is online now
AKA: Alex Tannahill
Re: Warming up the batteries
Our drivers had a similar problem with the cold. I think it has to do with the physics of the battery.
The batteries are suppose to run at room temperature. That can mean different things. I would check the supplier's website for specific temperatures that they list.
- Arizona North
Unread 15-12-2010, 18:05
I'd wait until power-up, just to be safe.
I've seen what cold can do to a NiCad (admittedly not a lead-acid) battery at "warmer" temperatures of around 20 F--went from about 3-4V or so down to 2V or thereabouts in a matter of minutes. Yes, it was being used, but that kind of drop is peculiar. To make matters more fun, it went back up after I went inside for a couple of minutes. The lead-acid(?) 12V batteries were somewhat discharged already, but refused to work right until put inside and charged, so we grabbed a car to supply the power needed.
At 50 F, you might get away with it, but I'd keep it in the vehicle until right before you need it.
Unread 15-12-2010, 20:42
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
In other applications I've had good luck with a wrapping of a nice thick blanket and a handful of the chemical hand warmers.
Unread 15-12-2010, 21:38
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
I'm just waiting for either Ether or Al to chime in.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 15-12-2010, 21:52
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
We had our 12v batteries running 201 and 245's robots in a parade 2 weeks ago (Michigan suburbs north of detroit). It was freezing out and they had been sitting out all morning so they were at 32 F. The batteries tested at above 12v before packing (the warm school). While in the parade, they were slightly less but the robots ran the whole 30 minutes on 3 batteries.
The robots were sluggish, but nobody is going to question you changing the batteries before you start. I mean you need to take 5 min to turn it on anyway right?
I would not worry about 50 F weather. Its not their prime but it is alot closer the the optimal performance zone.
Unread 15-12-2010, 22:10
artdutra04's Avatar
VEX Robotics Engineer
Based on experience using the FRC batteries in a previous robot we built, as long as you keep the batteries somewhere warm until a few minutes before they're needed, you'll be fine in 50F weather. The large quantity of lead in FRC batteries will maintain a sufficient core temperature until you start using them (after that point, heat from the chemical reaction usually keeps them warm enough to keep going).
If the temperature is closer to (or below) freezing, wrap the batteries in hand warmers and insulation.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-12-2010, 22:25
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We were involved (and organized) this event as well.
Using 2007 robot, without the drivetrain (1 FP, 2 Globe, 1 Banebots, and the compressor total), we ran on 3 low batteries (one was questionable, the other two were not fully charged but decent at 11.9-12v no load). All of the batteries were sitting on the truck with the robot for a few hours before the parade. The elbow joint (2x Globe) will not run on less than 11v, so we could deplete the batteries less than 201 and 245 could.
It was cold enough for one of our plastic rollers on the claw to break when closing. It was, however, very thin, due to extensive lightening efforts.
However, unlike 201 and 254 (which had cRio-based 2009 robots), our 2007 IFI robot could boot in under a second (on tether). We changed the battery during the parade without issue.
Kettering Motorsports
Unread 15-12-2010, 22:41
DonRotolo's Avatar
Back to humble
FRC #0832
Without getting into the physics, "What Art Said" and you'll be fine.
17F is hard on a lead-acid battery, and even harder on a gel cell. Less than half capacity.
Unread 16-12-2010, 07:24
I agree, Art hit the nail on the head. Just leave the battery on the floor of your truck until you need it. Don't forget the lube in your robot is not made for low temps I bet and that will be as much of an issue.
Unread 16-12-2010, 09:40
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
FWIW think about it this way:
1. All batteries produce energy and power through a chemical reaction.
2. In order for a chemical reaction to occur atoms or molecules of the two reactants must interact.
3. Temperature is the average kinetic energy (i.e. speed) of the random movements of atoms/molecules.
4. When a battery is cold its molecules are moving slower than if it was warm.
5. Slow moving molecules collide/interact less frequently with each other, making reaction rates in the battery go down.
6. Slower reaction rates in the battery mean that the battery cannot produce electrons as fast as it could when warm, so it performs worse.
50F probably isn't that big of a deal, but warmer is better.
Unread 16-12-2010, 10:02
thelittlesister's Avatar
thelittlesister thelittlesister is offline
AKA: Ally George
FRC #0316 (LuNaTeCs)
thelittlesister is just really nicethelittlesister is just really nicethelittlesister is just really nicethelittlesister is just really nice
Send a message via AIM to thelittlesister
Maybe some one here can help us. Our battery will drop from 12-13 volts to 9-8 in 1 minute of just being plugged in no matter what the temperature is. This happens with all of our batteries and we can't figure out why. Temperature doesn't affect it and neither does the amount of time that is charging. We have done research to solve our problem but have had no luck. We are afraid that we might have the same problem next year because we can fix it if we can't diagnose it! Can anyone help? Thanks
-Ally
316
Unread 16-12-2010, 10:03
Electrical Engineer
Rookie Year: 1995
I agree with all of the battery comments. You should be fine.
Two more aspects of cold ambient affecting FRC robots:
1. The first is if your robot utilizes latex tubing. Latex changes its springlike properties dramatically at low temps.
2. The second is to be sure that the ambient temp and/or robot temp is well above the dew point. The electronics, if cold, can condense moisture from the air and can make things interesting.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 16-12-2010, 10:04
Electrical Engineer
Rookie Year: 1995
-Ally
316
Ally,
It sounds like you may have a faulty battery charger.
Mike
Mike Betts
Unread 16-12-2010, 10:16
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
-Ally
316
Originally Posted by Mike Betts View Post
Ally,
Mike
^This.
Or some part of your electrical system is damaged. Or the batteries are just getting old. Does this happen to every robot it's plugged into or just one? How old are the batteries? Any idea how many charge cycles they have been through? Ever load-tested any of your batteries?
batteries on the controler coolguybigt Control System 6 25-02-2007 11:43
YMTC: The Twelve Batteries of Christmas Natchez General Forum 5 04-02-2007 14:44
Nasa study on Global Warming thegathering Chit-Chat 11 28-09-2006 07:18
Charging the 7.2 Volt Batteries roboticsguy1988 Control System 43 17-01-2006 20:59
Slightly humorous story about global warming & space explor. archiver 2001 3 24-06-2002 04:01
