Go to Post "Things should be as simple as possible, but not simpler" - Albert Einstein - Edward Debler [more]
Unread 08-12-2010, 16:39
cheezburger's Avatar
cheezburger cheezburger is offline
FRC #0686 (Bovine Intervention)
cheezburger is an unknown quantity at this point
software version problem
Trying out a java program right now, but will not run.
Netbeans gives error message stating it expects FRC_2010_v19.zip but is getting FRC_2010v20.zip
The website the error directs me to, http://first.wpi.edu/FRC/frcjava.html, says that v20 is now supported and required, but netbeans still says it expects v19. anyone know what the issue is?
i can has cheezburger?
Unread 08-12-2010, 19:19
Re: software version problem
That happened with an earlier WPI Java release. Do you have the latest updates applied?
Java doesn't actually have any problem, but there was/is a script that didn't get updated at time of the introduction of v20 that performs a simple check if v19 = the cRIO version. It got updated in a later release.
The fix at the time was to modify the script, but I'd have to go looking again to locate where it was. It wasn't in the Java folder as I recall.
Found it
Unread 15-12-2010, 15:40
So it says to edit file sunspotfrcsdk/ant/upgrade.xml.
Where is this file? I got a lot of stuff to look through and I don't want to waste time.
Unread 15-12-2010, 15:52
C:\Documents and Settings\username\sunspotfrcsdk
Where username is the login account the FRC software was installed under.
If you can't find it just do a windows search for "sunspotfrcsdk"
Unread 16-12-2010, 09:57
Before you edit any files, you should confirm that you have the plugin FRCSquawkSDK version 3.38 installed. If you have an earlier version, you need to update.
There was a few days between when the v20 image was released and when java was updated to support the v20 image. That was the only time editing the file might have been necessary. What the error message is telling you is that you don't have the latest java update.
Unread 19-01-2011, 15:36
Thanks for all the help, everything is working now.
SOFTWARE PROBLEM!!!! PLEASE HELP!!! RedHeadRobotics Programming 28 21-02-2010 16:07
WPILib version 4.2 for C++ seems to have a camera problem Randy Forgaard C/C++ 6 19-02-2010 07:51
software update problem qpang General Forum 1 22-01-2010 19:08
NXT Kits: Education Version vs. Commercial Version Richard McClellan Robotics Education and Curriculum 5 20-08-2008 16:29
