Go to Post Hall of Fame FIRST Team 254 has arguably helped more teams become good than any other team in FIRST. I don't think they need a lecture on helping their opponents. - Karthik [more]
Unread 17-12-2010, 13:01
team3329 team3329 is offline
None #3329
team3329 is an unknown quantity at this point
Communication Between Driverstation and the Robot Main
Hey does anyone know how i can us a boolean controll on the dashboard to set a certain value on the deployed robot code? Im using labview.
Unread 17-12-2010, 14:22
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Communication Between Driverstation and the Robot Main
Simple answer: It is very difficult. This would require you to write a TCP communication system, to send that bit of data.
Somewhat helpful answer: You can use the Virtual IO if you aren't using the Cypress board.
Kettering Motorsports
Unread 17-12-2010, 14:24
The Dashboard is for display only. It can show you what the robot is sending, but it can't do anything to change what the robot is receiving.
If you want to change a boolean value during development, you can put a control on the Robot Main front panel, then simply run Robot Main instead of building and deploying it. Part of the build process strips the front panel from the VI, so you won't be able to do that during competition.
If you want to change a boolean value using code you've set to run as startup, you have two options. Either use a physical control on a USB-connected device (joystick, gamepad, or Cypress I/O module), or use one of the emulated Cypress switch inputs in the Driver Station application.
Unread 17-12-2010, 14:51
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
...A TCP communication like the ZomB Dashboard! Alpha 5 has support for sending stuff back to the robot. (C++ only at the moment, I'm currently in the process of making java and Labview bindings). Is it competition legal? possibly, the GDC last year said yes and no, but it is definitely legal for dev use.
First forge site: http://firstforge.wpi.edu/sf/projects/zombdashboard
Watchdog.Kill();
Dashboard and Robot main with Axis camera Team2883 General Forum 9 10-01-2009 07:35
THe connection between the InviEW software and robot Spartan2432 FRC Control System 0 04-01-2009 13:25
Serial communication between RC's knine143 Programming 4 23-08-2008 23:36
FAHA: Communication between mentors Bharat Nain General Forum 5 01-01-2008 12:38
communication between the robot controller and the interface Shlomi32 General Forum 4 05-12-2005 16:53
