Go to Post "Why use a CNC when you can get it done with wood, duct tape, and zipties!" - gcgeobuff [more]
Unread 17-12-2010, 16:29
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
festo not responding to computer commands
FYI, this isn't a programming question, I'm pretty sure our problem isn't with the program.
Our Festo solenoid valve works fine, but it will only switch when we use the buttons on Festo itself. If we disconnect the cables to the solenoid, it will fire just fine from pressing the buttons. But when I connect the cables, the lights on the solenoid show just what they should (The bottom is on and the top is off when the tirgger on the joystick is off, and the opposite when the joystick trigger is on). But it seems as though the solenoid valves completely disregard what the lights say, and we can only control it with the buttons on the Festo.
Does anyone know what might be going on, or does it sound like the internal electronics in the Festo are broken? We've pretty much ruled out anything else that could be wrong, like the connection from thew Festo to the cRIO.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 17-12-2010, 16:50
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Re: festo not responding to computer commands
Just a quick check -- we've made this mistake before.
Is it the right voltage? A Festo labeled as 24 volts won't work with a solenoid bumper configured for 12.
This is the only possibility I could think of, assuming you checked (with a multimeter) that the voltage is actually getting to the festo.
I hope this helps.
Joining the 900 Meme Team
FRC #0079
Are you sure you are providing the proper voltage? If I recall correctly some of the valves sent last year were 24v rather than 12v.
Unread 18-12-2010, 05:23
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
Also, some of the valves have a required minimum air pressure to function, I believe it is > 35PSI.
Unread 18-12-2010, 09:21
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
If the solenoids are the ones linked to below...
http://team358.org/files/pneumatic/F...structions.pdf
Then...
If you are providing power to pins 1 and 2 as stated in the datasheet, then you may run into problems with some of them.
A few that were produced(actually I think quite a few) are improperly documented and you actually need to power pins 1 and 3.
If the wiring was wrong, the valves will do the same thing they are doing in your description
Hope it helps!
-Kyle McGurk
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Spikes Not Responding May_Walter Electrical 5 11-03-2010 12:37
CRio Not Responding Shadow_Cat NI LabVIEW 7 13-02-2009 08:12
Motors not responding to joysticks indubitably FRC Control System 6 08-01-2009 16:14
grab frame not responding ahmed LabView and Data Acquisition 4 28-01-2006 10:49
STAMP II not responding to computer archiver 2000 4 23-06-2002 22:24
