Re: Native call
There is a diagram disable structure in the same palette as while loops, for loops, and case structures. Just drop that on top of what you want to disable.
Re: Native call
Please let me know if you can reproduce these results.
I placed the ZomB Init.vi into Begin.vi and changed it to be configured to call into the ZomB.* library within the dialog. This failed to run button deploy until I ftp'd the ZomB.out into ni-rt/system, and then, as expected, Begin.vi would run fine. I built an executable that included Begin, deployed and rebooted to see it running. As far as I can tell, the call was successfully made to ZomB.out to init. It did not return an error. If it doesn't work please give details of how it fails. Greg McKaskle |
| Java Native Interface (For using code made in windriver) | biojae | Java | 3 | 07-03-2010 22:46 |
| LAST CALL! | Amanda Morrison | Awards | 2 | 22-02-2008 10:21 |
| Official Native Win32 version of GNU Make | Astronouth7303 | Programming | 0 | 05-01-2007 00:59 |
| Call me an optimist... | Eric Tarnowski | General Forum | 3 | 02-10-2001 16:55 |
