Go to Post Being the GDC is not an easy job, anything can happen. Lunacy happened ::rtm:: - Conor Ryan [more]
  #31   Spotlight this post!
Unread 17-12-2010, 19:22
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: [BB] The FRC staff doesn’t know it yet, but we’re having Haagen-Dazs at 2
Originally Posted by JaneYoung View Post
I think this is another way to reach the alumni from the teams. They are also gauging that impact, etc.
It's all about reaching the alumni, I think.
Power building power disguised as a game. If you don't play by voting, you help to skew the numbers.
Jane
So...much...thinking...
  #32   Spotlight this post!
Unread 17-12-2010, 20:12
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Stairs for the win.
  #33   Spotlight this post!
Unread 17-12-2010, 20:56
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
I think there my be more to Bill's Blogs than meets the eye...
Lets take "The view from 30,000 feet" for example. A quick search of flight at 30,000 feet finds this
"Depending upon the length of the flight and the type of aircraft, cruising altitudes typically vary between approximately 25,000 feet and 40,000 feet. For longer flights, it is not uncommon for an airliner to change cruising altitudes several times, gradually working its way to higher levels as it burns off fuel and becomes lighter in weight. This process is known as a step climb. For every flight, there is an optimum cruising altitude that is calculated based on weight. The step climb process is used to keep the aircraft at the optimum altitude as the plane's weight decreases over time."
Read more: Why Do Planes Fly at 30,000 Feet? | eHow.com http://www.ehow.com/about_4572148_wh...#ixzz18QLsb32b
The already pointed out fact that they took the group picture on the stairs...
For some reason the number 2 or two has been highlighted in some of Bills more recient posts. I wonder what this may bring?
  #34   Spotlight this post!
Unread 17-12-2010, 22:29
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Maybe there are two steps on the field, leading up to a central platform of some sort?
...or we could be interpreting this completely wrong, as usual, and the "2" is referring to the number of game pieces on the field, or the length of the match, or the number of minutes it takes to consume one tub of Haagen-Dazs.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #35   Spotlight this post!
Unread 17-12-2010, 23:36
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Very interesting. Stairs were always fun and challenging!
  #36   Spotlight this post!
Unread 18-12-2010, 00:24
2-minute teleop period, folks. Nothing to see here, Bill's just reinforcing an assumption.
Or 2 alliances. Same comment as above.
Or... He thinks that we're all 2 crazy right now, and is messing with our minds. What else is new?
P.S. What was significant about the number 5 in the official hint from 2007? Not the background, not the tube around it, just the number.
Spoiler for answer:
Spoiler for keep looking:
Spoiler for follow the rabbit trail:
Spoiler for OK, fine, you can stop singing now, if that's what it's called:
Anything between "not a whole lot" and "absolutely nothing".
  #37   Spotlight this post!
Unread 18-12-2010, 13:22
Onward through the fog.
I find that in many areas of FIRST/FRC - a lot of thinking takes place. Strategy isn't just built into a game - it is built into the business aspects of successful companies, corporations, non-profits. In FIRST's case, they want to market the mission and goals well and celebrate milestones. What better way than to ask for people who have been involved in FIRST over the years - some since the beginning - to vote on their favorite games. That information is useful in many ways but the hook is the game.
For one thing, the members of the Game Design Committee love to make us think. They love to make the engineers think. Thinking is a big big part of being on an FRC team. The sooner we realize that, the more fun there is to be had. The business side of FIRST is capable of doing the same thing, using strategy and organizational planning in gathering information while engaging the teams and others in the process.
Jane
~ Helen Keller
(1880-1968)
  #38   Spotlight this post!
Unread 18-12-2010, 14:41
DonRotolo's Avatar
Back to humble
FRC #0832
The evil Game Design Committee, you mean
As we tear apart every word from Bill (and Dave and ...whomever) to speculate on next year's game (3 weeks folks!), keep in mind the people behind the words.
Bill is ex-military. "Stand By" and "View from 30,000 feet" are just part of the vernacular of the military world. I see no hints there.
And Dave's a warm & fuzzy guy with cars dodging green men on Mars - thus a green fuzzy tennis ball.
Stairs? I dunno. Maybe that photo on the stairway WAS the only place for a decent photo. Boy would I love to see the challenge of a couple 8" tall steps.
Red herring? Nah, I see red and blue herrings...
Let the games begin!
  #39   Spotlight this post!
Unread 18-12-2010, 14:59
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
If anyone watches WWE, maybe this year is sort of a Money in the Bank match. Where you have to climb a ladder(in this case some stairs) to reach a briefcase(in our game could be anything) that grants you ultimate power. Could be a points multiplier, free for all with scoring on any goals(if goals are part of game and are seprated by alliances), could be a timed kill switch against the other alliance. Now wouldnt that be fun =]
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #40   Spotlight this post!
Unread 18-12-2010, 18:59
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
For those of us that live in an RGB world, are there also green herrings?
-dave
  #41   Spotlight this post!
Unread 18-12-2010, 19:28
pfreivald's Avatar
AKA: Patrick Freivald
-dave
...of course their are! (We attach them to little herring hamster wheels to harvest green energy from them...)
And Rees: Clearly you are thinking about this all wrong. Our robots will have legs, and will have to do the Two-Step!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #42   Spotlight this post!
Unread 18-12-2010, 20:03
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
Wink Re: [BB] The FRC staff doesn’t know it yet, but we’re having Haagen-Dazs at 2
-dave
Am I the only person that sees this as a possible three alliances? This could be a major game changer... I didn't think the answer would be right in front of me, does this mean there will be 3 alliances of two?
  #43   Spotlight this post!
Unread 18-12-2010, 20:05
ATannahill ATannahill is offline
AKA: Alex Tannahill
Yes you are the only person.
Everyone else sees it as Dave punching you in the cerebral cortex. Dave is the vacuum of time and common sense.
- Arizona North
  #44   Spotlight this post!
Unread 18-12-2010, 20:23
AKA: Matt B
FRC #1771 (1771)
-dave
Then you obviously haven't gotten the new Sharp Aquos TV...
RGBY...
So, 4 alliances?
  #45   Spotlight this post!
Unread 18-12-2010, 22:51
dlavery's Avatar
Curmudgeon
Oooooh!!!! New user title!!!!
New Game Hint? - Crackerjacks, Haagen-Dazs cups and Diet Coke cans? EgROS Rumor Mill 130 29-04-2011 20:05
Congrats to the staff of BattleCry KathieK Thanks and/or Congrats 5 19-06-2007 11:08
Ucf so soon...but yet sooo far away Ryan Albright Regional Competitions 20 23-03-2003 21:19
Kudos to the FIRST staff archiver 2001 1 24-06-2002 03:35
Team Update #7 - not out yet, but read this. archiver 2000 0 23-06-2002 22:59
