Go to Post Each match is a learning experiance - the only thing you can do is get better. - SuperJake [more]
Unread 19-12-2010, 09:04
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Sprockets as Chain Tensioners?
We call them Chinese stars......they work great in a pinch, but I typically shy away from designing them in. They can be tricky.
Mcmaster sells a flexible style, way over-priced.....McMaster 5896k1. We usually just stick an AM sprocket in there and let it go.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 19-12-2010, 09:07
Originally Posted by ajlapp View Post
They can be tricky.
Could you elaborate on that a little bit? Tricky how?
Unread 19-12-2010, 10:44
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
We've used them on many drive systems as tensioners with #25 chain. However, we also use them to drive encoders to keep track of the robot during autonomous mode on a live axle (dual purpose device) with shims to adjust tension.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 19-12-2010, 10:59
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Look at post #18 in this thread. Is this what you are referring to?
http://www.chiefdelphi.com/forums/sh...t=43750&page=2
Or, are you talking about placing a sprocket on some type of bracket and using that as a tensioner?
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
We've used them before with 25p roller chain, and they work great. After you first install them you need to keep constantly adjusting them every match or so during your first competition or so. Once the roller chain finished stretching, we left it in the same spot and never really needed to adjust it.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-12-2010, 11:35
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Sprockets tend to be heavy. While a sprocket on a tensioned arm or inserted between the chains can make a good tensioner, you pay the weight price. There are other less weighty ways to tension your chain, though the sprocket mounted on an arm makes a great one.
Unread 19-12-2010, 11:48
AKA: Anthony Lapp
Chris captured some of the problems above....
If you deploy a floating star tensioner on a long run of chain, the system tends to "slap" back and forth under load. Hard to explain without a diagram. This action can eventually through the tensioner.....especially if the chain tries to twist at all.
The point is, if you can design to the proper center distance and plan for a tensioning device, say a bolt or cam, I believe it will be more robust for competition.
We have used these in the past many times, but always as a fix, never as the planned way.
Anthony Lapp
RobotOpen
Unread 19-12-2010, 12:41
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
Thanks!
Team 955
Raiderbot
Unread 19-12-2010, 13:01
AKA: Anthony Lapp
You could try a cam....see the picture below. Each cam has a 1/4" shoulder bolt that acts as an axle. The bolt is drilled off center. You twist the cam into the desired position then tighten a set screw....this drives the aluminum cam up into the bolt and locks everything down.
As the delrin wears you can adjust the tension or replace the bushing altogether.
Anthony Lapp
RobotOpen
Unread 19-12-2010, 14:13
NickE's Avatar
NickE NickE is offline
_
Keep in mind that anything you add into the chain run will add friction and decrease the efficiency of the system.
The only way to avoid this is to either size the center-to-center distances perfectly so that no tensioner is needed or to have a system where the axles slide to tension the chain.
Unread 19-12-2010, 15:20
Does anyone have any data quantifying this effect ? At least some ballpark numbers. It would be useful to know just how "floating sprocket" tensioners, rotating tensioners, sliding tensioners, and adjustable axles compare.
Unread 19-12-2010, 15:27
Chris is me's Avatar
AKA: Pinecone
I've been interested in making a simple test bed for something like this but I have no idea what I should be measuring - I assume current draw?
Personally I'm going to wager a guess that friction in tensioners is essentially negligible. Shaker just uses blocks of Delrin or nylon pushing against the chain (not spinning) and we have no problems at all. We even had a multi-purpose Delrin rod we used as both a tensioner and as a structural member (standoff)
Unread 19-12-2010, 15:47
You need current and speed, or current and voltage, or voltage and speed.
Ideally one of the two parameters is held fixed to make it easier to compare.
If you can measure all three then the extra data can be used as a cross-check of the test's integrity.
Unread 19-12-2010, 18:36
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I doubt that a static tensioner has a negligible effect on efficiency.
If you've got a two stage spur gear reduction and a single chain run from the gearbox you're already down to 83% efficiency or so. If you then shove a block of plastic into the chain to tension it, it would seem you would be liable to lower efficiency quite a bit.
We have no data, but empirical evidence has suggested to us that our overall drivetrain design is noticeably more efficient than the average drive similar to ours in terms of same number and type of motors, similar gear reductions, top speeds, and wheel type/friction.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-12-2010, 18:15
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Chain "stretches" (actually, it is wearing, not stretching, but the end result is the same) and gets longer with use. A system that is initially designed with perfect spacing will end up with loose chain as the system is used.
Zan Hecht
AndyMark Chain Tensioners CodyHarris Kit & Additional Hardware 2 28-03-2010 13:29
pic: Integrated, easy to use chain tensioners Jon Stratis Extra Discussion 9 21-02-2010 22:37
pic: Sliding Wheel Chain Tensioners Ice Berg Extra Discussion 18 22-04-2009 00:45
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
