Go to Post 20,000 students 900 teams robots Gracious professionalism = FIRST - Bcahn836 [more]
Unread 16-12-2010, 10:14
gilkeedman gilkeedman is offline
Team captain/Pneumatics/Mechanics
AKA: Gil 'Dil Tedem' Kedem
FRC #2630 (Thunderbolts)
gilkeedman is an unknown quantity at this point
Where can we find good pneumatic wheels?
Me and my team trying to learn about good and diffrent drivetrains than those we used in the past few years and we want to see more about pneumatic wheels (for example 1114 wheels at 2010)
so those anybody can help us to find good pneumatic wheels?
2007 - Israeli regional FLL team member, 2008 - Fomula Green-8075 FLL team member, Israel's champions
2009 - Israel FLL referee and Thunderbolts team member
2010 - Thunderbolts, Israeli regional champions, Curie semifinals
2011 - Thunderbolts captain
Thunderbolts 2630 website!!
Unread 16-12-2010, 11:29
Re: Where can we find good pneumatic wheels?
50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary.
Unread 16-12-2010, 11:44
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
"You must spread some Reputation around before giving it to Joe Ross again."
That's an awesome stat Joe.
GitHub
Unread 16-12-2010, 13:58
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Wow, just wow!
1058 PVC Pirates 2016 - xxxx
Unread 16-12-2010, 15:05
It should also be noted that:
1) Said wheel does need some hub modifications to use in FRC--the stock hub configuration has a hard time with attaching a sprocket.
2) Spare tires are a must if you do drive practice. A lot of those tires showed red (and inner lining) by the end of the season, and the batteries were constantly on the charger due to the amount of drive practice put on them.
Unread 17-12-2010, 03:32
Yalib Yalib is offline
Yalib is on a distinguished road
I'm also a member of 2630,
We checked out the mcmaster wheel and it looks really good, Do you know if this wheel has a tenon slot?
Unread 17-12-2010, 11:13
You mean a keyway? Not stock--you'll have to modify the hub. It's designed to be used as a caster (unpowered), so any powered use needs modification.
Unread 17-12-2010, 14:19
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Any pictures or drawings of how you did the hub modification? Did you actually modify the hub or fabricate an adapter between the hub and the sprocket.
-T
Unread 17-12-2010, 14:53
I forget how we did it in 2005, but the hub itself is 3-4 pieces. 2 of them are rims, sandwiched between hub pieces. The hub pieces get modified/replaced.
In 2006-2008, we used a custom adapter to hold the rims in place, and a spacer to keep the sprockets separate. I don't have plans or pictures readily available; ShaneP might have some better ones.
Oh, and using 6 of these wheels on a 6WD is asking for turning problems, even with a dropped center wheel.
Unread 17-12-2010, 17:23
Aren_Hill's Avatar
Build Nifty Things
I got yelled at when i stated those sort of statistics, something about sample size, only mine was even more restricted than yours,
"6wd swerves have a 100% chance of einstein historically"
on topic:
I wish someone made a good 4" pneumatic wheel
A guy who likes robots.
Unread 17-12-2010, 20:22
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
The pneumatic tires on 494, 70, (and of course 469 on Einstein this year)were from MBS Mountainboards. They were an 8" knobby black rubber tube tire with a glass filled nylon hub. They are intended to be used on, get this, mountain boards.
We've used the same tires / hubs several years and never had a flat or a broken hub. I think these are far superior to any wheel/tire made for FIRST robots. Of course the tread will wear down, but we've been able to get through a season before we've completely destroyed a set.
MBS is located in Colorado Spring, CO. They have fair prices and good delivery. You'll see on their website a beautiful looking set of 6061-T6 aluminum hubs. I think this is what the fashionable robots will be wearing this season. Be a sport and wait till I order mine so they don't run out
http://www.mbs.com/
Jay
Unread 17-12-2010, 20:25
AdamHeard's Avatar
Lead Mentor
Are those the same wheels 1114 used?
Unread 17-12-2010, 20:48
Yes
Unread 19-12-2010, 00:51
topgun's Avatar
What kind of turning problems? Slow, or bumping, or fuse blowing?
Or are you saying you don't use 6 of these wheels on a 6WD?
How do you overcome the turning problems?
-T
Unread 19-12-2010, 13:07
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
http://www.radioflyer.com/22w-0642699.html?sid=5
with slight modification these work pretty well. they are light and durable as well.
in past years my team has mad an axle with a disk on it, then the radio flyer wheel is bolted to the disk in a similar manner as a car wheel.
Where can I find gears? vivek16 Technical Discussion 16 13-05-2008 08:38
where can I find it? kDude Control System 3 22-01-2008 17:50
Pro/E...Where can I find it? vedas Technical Discussion 4 21-04-2004 23:45
