Go to Post A career is never static. - Bill Moore [more]
Unread 27-11-2010, 14:24
kdickie kdickie is offline
FRC #3336
kdickie is an unknown quantity at this point
USB Thumb drive fails to image new classmate
We had to purchase a new Classmate to replace the FIRST supplied Classmate. We are attempting to image it using the USB thumb drive recently supplied by FIRST. We followed the instructions found at http://decible.ni.com/content/docs/DOC-9556. The process failed once it got to the x:\windows\system32\wpeinit claiming restoreds is not recognizable. We determined that restoreds is a command line “script” that had references to an image file (10-2-09image.wim) files located on a “D” drive, presumably the thumb drive. We discovered that the thumb drive was actually the “f” drive and changed the path to look for the image on the thumb drive. This allowed the process to continue past the error. Now, the process gets past the partitioning and attempts to install the image. The process gets to 19% and errors complaining about a corrupt UDP.llb file.
At present the Classmate will not boot complaining about a missing \system32\hal.dll file, likely because the image was not fully restored.
We have repeated the above with the original restoreds file (pointing to “d” for the image) and we get to 19% and error with the same results.
It seems that our image is corrupt, however we just received this copy from FIRST.
Any advise?
Unread 27-11-2010, 14:33
Re: USB Thumb drive fails to image new classmate
When you say you bought a new classmate, did you get the exact same model as what FIRST supplied? The usb stick contains the drivers for that specific model and should not be used for a different model.
Unread 29-11-2010, 20:12
FRC #3336
We ordered the classmate recommended by the game committee in the first forum thread http://forums.usfirst.org/showthread.php?t=13805. This is for a classmate E10IS. What we got was an E10IS2. Hope this is correct! I am concerned that due to a year passing that even though the model is the same (kinda) some slight hardware changes have occurred and drivers might be different. However, since the "Imagex" utility (according to Microsoft TechNet) is simply some sort of file copy and path table, it would seem that if this is the issue that the "Image" would have worked, but hardware might not function correctly. This was not the case as the Image failed. Any thoughts?
I am starting to think the USB key really has a corrupt file (UBP.llb - which FYI, I have learned is an un-needed labview "exmaple" file)
Thanks for any insight, we are stuck!
Unread 30-11-2010, 17:38
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
what you need to do is get a copy of windows xp (on a thumb drive), then re-format and partition the hard drive on your classmate, you only need 1 partition. first, set the BIOS to boot off the flash drive, then it will show partitions, delete the partition, and make a new one, make sure that the format you select is NTFS. after re-partitioning it, install windows, setting it up with developer as the admin account after installing, it will reboot off the hard drive. then you make another account, this will be driver. once that's done, you can install the driver station and dashboard. all programs you put on it need to be transferred via flash drive until you have a browser in.
in other words, do a vannilla XP install
or you could borrow an image key from another team
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 30-11-2010, 18:07
Have you personally actually successfully done this on a Classmate, without additional steps not mentioned above (like acquiring and installing 3rd party drivers and/or editing configuration settings not described above) ?
Unread 30-11-2010, 18:25
joek's Avatar
not on a classmate, but I have installed windows on other computers, but I realize that they may be quite different and complex.
that's why I mentioned borrowing an image key from another team
Unread 01-12-2010, 21:49
FRC #3336
We hope to take a similar path that may by-pass the driver issues. We have requested a Restore CD from CTL that should boot from a USB drive (just like the thumb drive). This should hopefully restore the Classmate back to out of the box (Win7). At that point we should be able to install labview (from the CD's) and the driver station software (from the latest update in FIRST. I have asked FIRST about win 7 and they indicate it will work.
Any thoughts?
Unread 02-12-2010, 22:42
joek's Avatar
Any thoughts?
is the classmate powerful enough for 7?
Unread 03-12-2010, 10:10
FRC #3336
According to FIRST it should work. however, I may have hit a roadblock, clt now tells me they do not offer "restore CD's" for windows 7 since one can be made from the win 7 partition. NOT GOOD for us since the FIRST USB key re-partitioned the drive and this will not work. options I am investigating:
1. Get an XP restore CD from clt. I am not sure if the "restore" CD's will still attempt to access the wiped out partition of if the CD has everything it needs.
2. Install WindowAIK (automated installation kit) on a "technition" pc and mount the Image that FIRST supplied (that has the corrupt UDP.llb file) and use ImageX to modify the image by deleting the file and then attempt to reimage. This is WAY outside my comfort zone and have printed a few hundred pages of Microsoft TechNet doc's.
3. Buy either XP of win 7, and do a clean install and then fight driver problems.
4. Beg FIRST for a new image to see if it was just a freak corruption.
5. Get another team to make a restore CD from there classmate. Again I am not sure if it will work with the wiped partition. This may also open up driver problems due to the restore CD installing XP.
None of the above are very appealing.
Ideas very welcome!
Thanks everyone.
Ken
Unread 19-12-2010, 18:42
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Any thoughts?
It should work - the beta hardware we've been working with runs windows 7, and the new version of labview for the season states it supports 7 as well.
USB Encoder to ClassMate PC Warren Boudreau FRC Control System 2 03-02-2010 09:37
Camera not sending image to Classmate? TPNigl Programming 14 22-01-2010 17:05
Rules of Thumb for New posters and FRC Participants Al Skierkiewicz General Forum 0 08-02-2008 23:33
Robot USB Drive Jeremiah Johnson Chit-Chat 3 26-04-2007 13:04
MPLAB on USB flash drive ultramrw21 Programming 3 25-01-2005 21:20
