Go to Post hmmm... big open space between arena and pits... thousands of poof balls...thousands of high school kids hopped up on sugar and robotics.... sounds a little dangerous. - Courtneyb1023 [more]
Unread 19-12-2010, 14:50
renglish renglish is offline
FRC #1413
renglish is an unknown quantity at this point
Chains for 6 wheel drive
We are building a prototype to test 6 wheel drive. Could someone tell us the best way to arrange the drive chains?
Unread 19-12-2010, 14:52
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Chains for 6 wheel drive
Can you put up a picture of what your current drive configuration is?
-RC
R.C.
MadTown Robotics Team 1323
Unread 19-12-2010, 19:00
Depends. Where is the gearbox?
Unread 19-12-2010, 21:00
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
here are are a few photos of our rookie year drive train. You might get a few ideas from this:
http://www.chiefdelphi.com/media/photos/27588
http://www.chiefdelphi.com/media/photos/27587
Unread 20-12-2010, 10:20
TJ Cawley's Avatar
TJ Cawley TJ Cawley is offline
THE Freshman
FRC #1108 (Panther Robotics)
Team Role: Driver
TJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the rough
does this method of chains work well?
i've been prototyping chain drives and never though of 6-wheel power but it seems like a good design. do you use 3 chains per side? you could extend the drive chain so that it wrapped around the first two wheels, like on a caterpillar. that way you'd only be using two chains.
"To create a world where science and technology are celebrated... Where young people dream of becoming science and technology heroes"-Dean Kamen
This should start each year by focusing on worldwide issues, and having a game that, in theory if not practice, will help fix or compromise a solution with those issues, to make a better, safer worldwide and FIRST community.
Unread 20-12-2010, 10:28
wilsonmw04's Avatar
Coach
two chains were used. 1 drove two wheels and was powered by one CIM. The other chain drove the front wheel getting power from the middle.
Unread 20-12-2010, 11:50
330's setup has typically been 2 chains off the gearbox, one to rear, one to middle, and 1 chain from middle to front. Gearboxes were aft, which helped the robot settle on that side for slightly more stable driving. (6WD drop center)
Unread 20-12-2010, 15:06
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
We used a similar setup this year. Two chains from the gearbox (to middle and rear wheels) and one chain from the middle to the front. Again, gearboxes were aft of center, but tensioning was a nightmare (we were using #35 chain).
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 20-12-2010, 15:12
wilsonmw04's Avatar
Coach
Our set was way easy to tension. All we had to do was slide the motor shaft fore or aft to tension the back chain. The front chain was tensioned by sliding a small PVC pipe along the length of the chain and zip tying in place.
Unread 20-12-2010, 15:19
Have you been following the discussion in this thread? Static (ie non-rotating) tensioners are not receiving a favorable assessment over there.
Unread 20-12-2010, 15:26
Chris is me's Avatar
AKA: Pinecone
It's a lot easier to use one chain per connection than it is to use a single chain for multiple wheels. So 2 chains off the box and one chain from a wheel to another wheel.
Unread 20-12-2010, 15:39
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Another alternative that I don't believe has been mentioned yet is:
Direct drive one set of wheels, then use chain to drive the sets.
For instance, direct drive the center set, then run a chain from center set to the front set and another from the center to the rear set. This can also be done by driving either the front or rear set of wheels and then chaining up the remaining sets. If you use #25 chain, this will also yield the lightest use of chain.
We have used this setup, as well as many other teams, with great success. The one caveat is to make certain your alignment and tensions are correct.
One not so obvious advantage to this design is that a single chain break will not cripple your drive train. In fact, multiple breaks might not either.
Unread 20-12-2010, 16:43
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
You can really route your chains just about any way that you want, provided you have enough chain wrap around each sprocket. Teams have had success with just about everything.
My favorite method so far is a using just a single chain to provide power to all the drive wheels on one side (example here). It makes for a nice simple system that's easy to work on, but if the wheel sprockets are slightly eccentric it can be a pain to tension correctly.
Unread 20-12-2010, 18:21
wilsonmw04's Avatar
Coach
We used that same approach for Lunacy. it worked very well.
Unread 20-12-2010, 18:50
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We did 6wd for Lunacy.
We drive the center wheels directly. Fronts and back wheels were driven by individual chains each slaved to the center wheel master. The center wheel, in addition to being directly driven, had dual sprockets. This worked well, kept chain lengths short, and limited the impact of losing a chain in a game (which never happened, anyway).
Spacers on the sprockets kept the chain runs straight.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
6 Wheel Drive, Wheel/Drive Assembly tiger1dd Inventor 37 10-05-2010 08:55
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Any pictures for Centered 2-Wheel Drive? phrontist Technical Discussion 9 30-04-2004 17:24
