Go to Post shhhh...our robot is in a bag now, it won't hurt anyone till the milwaukee wisconsin regional. hopefully it won't be fiesty. don't wake it. - Toatekua [more]
Unread 20-12-2010, 18:35
AdamHeard's Avatar
Lead Mentor
Re: Sprockets as Chain Tensioners?
My gut instinct is that the friction at the interface of the idler sprocket teeth with the chain would be a bigger factor (albeit still small) than the idler's ball bearing friction.
That's my guess too. Which is why it would be most instructive to see some real apples-to-apples data comparing a well-designed system to itself: with and without a tensioner touching the chain.
Aside from the increased efficiency, another reason we negate the idler tensioner is that it saves weight and reduces the overall part count.
It's easier for us to make a tensioner using a sliding bearing block than any other method, and it's agreed that it is most efficient. In drive, we don't even consider other options.
AndyMark Chain Tensioners CodyHarris Kit & Additional Hardware 2 28-03-2010 13:29
pic: Integrated, easy to use chain tensioners Jon Stratis Extra Discussion 9 21-02-2010 22:37
pic: Sliding Wheel Chain Tensioners Ice Berg Extra Discussion 18 22-04-2009 00:45
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
