Go to Post Think Tolerant. - petek [more]
Unread 16-10-2002, 22:59
Lord Fett Lord Fett is offline
#0064 (Gila Monsters)
Lord Fett is an unknown quantity at this point
Send a message via AIM to Lord Fett
Question Revolving Light Question
Someone I know online who is on a FIRST team is doing a paper on the revolving light and I don't know all the specifications about it. Can anyone tell me how the light revolves and information along the lines of that. Thanks
Unread 16-10-2002, 23:05
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Umm...
It's 12V
There's a motor in the base
The mirror on the motor focuses the light, making it appear brighter in that area.
That's all I can think of.... anyone else?
Unread 16-10-2002, 23:48
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Other than that ....
it has to be mounted upright on your robot and the light cover is a lot easier to change than it was in 2000 That's all I know.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 16-10-2002, 23:52
Andy A. Andy A. is offline
Getting old
FRC #0095
It has a wonderful habit of grounding your robots frame, so much care must be taken to ensure no part of it touches any conductive matieral.
The grounding problem is because most of the light's frame is it's self ground (much like car frames). You'd have to take one apart to really understand how it works. It's really rather simple, but confusing at first. I've played with one, but can't remember any details, other then the bulb gets very very hot very quickly.
-Andy A.
Unread 18-10-2002, 21:17
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
We took apart our old one to see what was inside of it, there is a little DC motor with a gear box. The i dont rember if the new lights have a revolving mirror or they have the 3 revolving fresnel lenses. Either way the lightbulb just sits in the middle.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 10-11-2002, 19:43
If you assemble all of the above posts you will have a good idea of how the light works and how to interface it. Let me add that most accessories designed for cars are intended to use the frame of the vehicle as one side of the electric circuit because it reduces the amount of wire needed by 50%. You need to mount the light on an insulating matierial. We use a thin sheet of lexan. You must then make an electrical connection to the shell or to the mounting hardware in order to complete the circuit. The downside of this light is that it draws about 4 amps continuous. That is a lot of current when you are near maxed out on the battery.
Unread 21-11-2002, 09:35
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
our team found that you could have fun making the light spin in the oposite direction by switching the polarity of the voltage going to it....
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 23-11-2002, 20:15
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
We like to have fun watching the light skip a turn as it gets radio interferance!
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 25-11-2002, 12:30
Elgin Clock's Avatar
FRC #0237 (Black Magic)
If you put the light, without a lens on, upside down in those halloween pumpkin containers that the kids use for candy, it looks cool!
It heats up pretty fast though so you have to keep an eye on it!
Unread 25-11-2002, 17:35
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Is there a way to make your light turn into a roating stobe light!?
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 26-11-2002, 01:19
Getting old
FRC #0095
While I imagine you could hook up some strobe circut to the light, I don't think the bulb is well suited to strobing. My bet is that it would either not strobe well or just burn out, depending on what you're using to strobe it.
Try and run the motor on that kind of current and it won't last to long either.
-Andy A,
Unread 26-11-2002, 08:26
You could put a strobe in place of the bulb but then you wouldn't need it to rotate. Circuitry for the strobe could easily fit inside the base if you take out the motor. This is an illegal mod to the light though, so don't do it for a competition robot.
There is a place in Chicago called the American Science Center that sells all kinds of stuff like that. Their website is http://www.sciplus.com/
I am lucky they are just down the street from work. They also sell surplus motors and FP transmissions that look a lot like what are provided in the kits. Their stock varies from day to day.
Only a few more days...
Unread 26-11-2002, 08:43
If your radio is cutting in and out, it looks like a strobe light ... ... ...
- Katie
Student - 2001-2004
Mentor - 2006-2009
Unread 27-11-2002, 09:48
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Sometimes we spend a whole lot of time developing overly complex answers when the simplest ones are perfectly acceptable...
Put vertical stripes of electrical tape on the inside of the light cover (the colored lens). As the light rotates, the beam will alternate between showing through the light cover between the tape stripes, and being occluded by the tape, simulating a strobe effect.
This method is dirt cheap, requires no additional electronics, and is easy to reverse if necessary.
Unread 01-12-2002, 02:37
MacZealot MacZealot is offline
MacZealot is an unknown quantity at this point
Send a message via AIM to MacZealot
illegal mod to the light? Why not stick a halogen in there and blind everyone in range. :evil grin:
AIM: Joe7464685192 | Email Me! Visit my site!
Uh I'm STILL not in Las vegas GRRRR!! I dun think it'll happen till june and This shoulda happened a freaking year ago
turn on the light - question powercat Programming 12 22-02-2003 17:33
Q&A Discuss: the revolving light CD47-Bot Extra Discussion 1 19-02-2003 13:33
the revolving light Alex Cormier General Forum 1 19-02-2003 11:32
compressor and light question... archiver 2001 5 24-06-2002 00:47
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
