#331
Re: 2011 Game Hint #1
Little Eva -> Uncle Tom's Cabin -> Civil War + Water -> Uss Monitor v Css Virginia -> Iron clad Game
#332
My theory revolves around the concept of the picture being reversed, or mirrored. I may or may not have gone a bit overboard on it, but whatever.
OK, so there are two types of symmetry: Rotational and Reflective. While working with videogames, I have discovered a fine example of the two: The game Team Fortress 2, which I map for. Anyways, every FRC game so far has had both types of symmetry, which while fair, is a bit boring. Enter stage left my hand dandy drawing. I didnt feel like making all other games, but trust me, they are all rotated, and have both types of symmetry. ![]() In my time working with TF2, I discovered a different type of symmetry: The reflection, which reflects the base over a line of symmetry. ![]() This is an example of rotational (only) symmetry. It allows someone on the red team to turn left at the exact same place that a member of the blue team turns left on their side. This allows people to only have to memorize half the field, or map in this case. Note the crossing arrows. If someone wants to go to the opposite identical portion of the field, then they must cross fully through the middle. ![]() This on the other hand, is reflectional symmetry. Both sides are reflected over the axis. If one team's player turns left, then the other right, and vise versa. It allows for a slightly more dynamic gameplay, possibly for the sole reason that it is not the norm. It is just different, and although one may not realize it, it will create a very different game. Now, you may say, how may this apply to FIRST, how could they make a reflectively symmetrical field? It would also allow them to use angled elements, something that is not possible in a rotationally symmetrical game. It should also be notes that it is quite hard to make a game piece through the LOS in a reflectively symmetrical field. My example of a field in this type: ![]() Anyways, Food for Thought. Other possibilities of the reflection: -Light based game -Red herring -It was simply there to stop people from reverse searching it -"Competitive co-op" There is a mirror across the field, and your team races vs the other team to complete an objective that doesn't require contact. |
#336
about 8 straight hours of posting every few seconds
#337
Don, Just get a nice big box of chocolate-covered maraschino cherries and a cup of coffee and settle yourself down for a fun read. You'll be amazed at the ideas that you are going to have pop into your head. Jane Last edited by JaneYoung : 21-12-2010 at 22:48. |
#338
HER MIDDLE NAME IS NARSSASIS THAT IS ALSO THE NAME OF A GREEK LEGEND IN WHICH A MAN IS SO PREOCUPIED WITH HIMSELF HE ALWAYS CARRIES A MIRROR...ALSO THE IMAGE IS FLIPPED (LIKE A MIRROR IMAGE) LASTLY SHE IS LEANING ON A COLUMN COLUMNS=GREEK
#339
The thing I think I'm going to say is everyone should probably sleep on this! (If your not going to sleep soon you should, the time for little sleep will come in 18 days).
Closing thoughts for the day until I resume alot of thinking and discussion tommrow. - Locomotion, must be involved with the name, or uses some sort of train. - The Pillar, I know alot of people are putting it aside, but I don't know guys, I feel like it has some importance. - Wackiest clue yet - Probably, my intial reactions was pretty off. We have alot to consider, but hopefully the next hint will clarify things. As I said before, I look forward to going back after the 8th and seeing how right or wrong we all were. oh and I wish I had a round table going tonight ... darn ![]() |
#340
Nobody has mentioned beehives. We must be out of practice with our over-analysis.
Yes, I searched the thread |
#341
I think we should list everything we haven't mentioned. Just in case we miss something. |
#342
Im still going with the Iron Clad idea... Mirror = Split right in the middle. So the Union and the Confederacy was split in the middle. Some one mentioned Eva being a character in Uncle Tom's Cabin that thought of drowning. Water + Civil war = Iron clad. Loco motion is railroads, that is how the Union won, with rail roads. 1962 = 100 + 1862, the second year of the civil war. Pillar = holding the house up. Without unity, the Union will ultimately fail.
#343
That's not a beehive, it is more along the lines of a poof.
#344
This is when these threads become useless.
People start posting things that have already been posted because they don't have the common courtesy to read first, or even try a simple search. Oh well, see you after the next hint. Last edited by IndySam : 21-12-2010 at 21:43. |
#345
| Waiting patiently for the 2011 hint! | Macdaddy549 | General Forum | 119 | 21-12-2010 10:58 |
| 2011 Game Hint | FIRSTtm134 | General Forum | 4 | 01-12-2010 06:24 |
| Game Hint #2 | Zflash | Rumor Mill | 539 | 07-01-2009 16:14 |
