Go to Post Easy, we use Magic. Your team wasn't given that in the kit? - Michael Hill [more]
Unread 22-12-2010, 12:26
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
gearbox design question
Never designed a gear box before. My question is (assuming andymark gears) how do you determine the correct inter-axle distance for a pair of gears?
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 22-12-2010, 12:48
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: gearbox design question
Try this,
http://www.team1323.com/resources/ma...alculator.html
Btw, Andy uses 20 DP gears, just enter tooth count after that.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 22-12-2010, 13:02
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The functional diameter for center-to-center calculations is the pitch diameter. This diameter is located in roughly the middle of the height of the gear teeth. It is often given as a dimensional property of the gear, or can be calculated from other properties such as the pitch, no. of teeth, diametral pitch, etc.
For a gear pair, add the pitch radii (half the pitch dia.) of both gears to find the center-to-center distance.
Andy-Mark supplies the diametral pitch (they call it the "diametric" pitch) for their gears, which is the number of teeth per inch of pitch diameter. Divide the number of teeth by the diametral pitch to find the pitch diameter:
(Number of teeth)/(Diametral Pitch) = (50 teeth)/20 = 2.5 inches
Pitch radius = 2.5/2 = 1.25 inches
A summary of spur gear properties here: http://shopswarf.orconhosting.net.nz/spur.html
Unread 22-12-2010, 13:06
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
All gears (and sprockets) have a pitch diameter, and all gears should mesh at this pitch diameter.
To find the pitch diameter for gears, take the total number of teeth on the gear and divide by the diametrical pitch (DP). For example, the 50t gear in an AndyMark Toughbox gearbox has a pitch diameter of 2.5". (50 teeth / 20 DP) = 2.5 inch
To find the theoretical center-to-center (CTC) distance between two gears, divide the two pitch diameters by half (to get the radius) and add together. For an AndyMark 50:14 reduction in a Toughbox, this is ((14/20) / 2) + ((50/20) / 2) = 1.6".
But in reality, you should add a small value onto this theoretical CTC distance; I usually add 0.003" to all calculated CTC values. This serves two purposes: 1) it adds in a small buffer to account for manufacturing tolerances, and 2) it's better for gears to "run loose" than it is to "run tight".
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-12-2010, 14:09
Brandon Holley's Avatar
Ditto the .003" number. On carefully machined gearboxes where I've used this tolerance, I've never had an issue with binding or wear.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
pic: 1881 new gearbox design GMAdan Extra Discussion 7 21-12-2006 01:59
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
How to design a gearbox? Hinkel Y. Technical Discussion 14 07-04-2004 23:06
A question about gearbox design . . Frank(Aflak) Technical Discussion 14 02-10-2003 14:57
