#16
Re: [FF]: FF Draft Assistant Rewrite
The event codes are the same as those listed at frclinks.com |
#17
I just fixed it so that it will not try to download a teamlist if the box is left blank. While the download attempt was harmless it set a flag to randomize the teams which may potentially be unwanted behavior.
I am also working on handling some additional errors (such as non-numerical characters in a teamlist) and displaying appropriate error dialogs to explain what's going on. |
#18
Crashed it by putting in a good pick list set... Reopened the program and it worked fine.
I think it doesn't like if a needed file is modified while the program is open. I don't know if there is anything that can be done about that, though. Also, a note: If you're generating a fresh draft setup, it's a good idea to remove old tiers--it'll pick them up as good ones if they're still around. (Saw that just now, going from my test draft (4 tiers) to AZ (2 tiers)--tiers 1 and 2 changed to AZ tiers, tiers 3 and 4 stuck around and were opened up when I started the program.) |
#19
If there is an error with the manual teamlist it can be edited and retried because the dialog box closes. I will probably implement a button or menu option to load lists in addition to the automatic prompt so that list files can be fixed without restarting the program. Quote:
#20
The program has been updated to better handle some errors that can occur (many still require program restart, but better inform you of what happened with dialogs).
It also now uses the FIRST pages directly for auto-team loading as the site I was using that provided the lists in XML is not going to be updated for this year's events. Installer still located here: http://www.chiefdelphi.com/media/papers/2307 |
#21
I have posted an updated version of the program at the CD-Media page listed in the previous post. If you have a version that does automatic team fetching, you can just grab the Update zip file and replace the main EXE with the one in the ZIP.
Changes:
As always, feature requests or bug reports are welcome via post, PM, email or IM Last edited by Vikesrock : 19-12-2010 at 10:48. |
#22
Can code-tags be in the settings somewhere? They're not universally used among the current draft runners (and I don't like them).
I mean, not that it's a huge deal; I'm just nitpicking. Last edited by Basel A : 19-12-2010 at 13:23. |
#23
I turned the autorun checkbox, which I never implemented anyway, into a checkbox to enable or disable the code tags. Eric, Alex and I all use them and Ed doesn't use the program so the default state of the checkbox is on. Updated installer and update zips Last edited by Vikesrock : 19-12-2010 at 13:38. |
#24
No worries! Flexibility is always a good thing and it was pretty easy to implement.
#26
Another thing. Can you implement a 'copy text' button.
#27
Hmmmm... that would be handy. Probably a little tougher to implement. I'll see if I have time to work on it before I go home for the holidays on Wednesday, depends how my project at work is going.
If I don't get it done before Wednesday I probably won't have time to work on it for this season of drafting because I won't have a development machine at my parent's. |
#28
I tried to uninstall and install the new version. I am getting an error message saying libgcc_s_dw2-1.dll is missing. I uninstalled and reinstalled but it still doesn't work.
#29
Looks like that dll can be found here: http://pt.sourceforge.jp/projects/sf...c_s_dw2-1.dll/ You can either put it in your C:\Windows\System32 directory or the GTK\bin directory inside your FF Draft Assistant install. Hopefully that's the only one that is missing *crosses fingers* |
#30
Done, now it wants libstdc++-6.dll.
I appreciate your help but I'd prefer you to work on the waiver wires and I'll draft manually. |
| Vision Assistant | Sykan | NI LabVIEW | 1 | 17-01-2009 16:43 |
| [moderated]: A Challenge: YOU Rewrite G25 | Tom Bottiglieri | General Forum | 10 | 30-03-2005 21:18 |
| [moderated]: A Challenge: YOU Rewrite G25 | Tom Bottiglieri | Rules/Strategy | 0 | 28-03-2005 09:35 |
| BuzzWriter - PBasic Assistant | archiver | 2000 | 0 | 23-06-2002 22:58 |
