Go to Post I would be thankful to just participate in champs, I would be happy with just that. - Brandon_L [more]
Unread 23-12-2010, 11:51
jtus jtus is offline
AKA: Just Jack
Rookie Year: 1994
jtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of light
Re: cRio Power Light Not Turning on and no Activity
We had the same problem. Just call NI and get a RMA number and send it to them. They returned it in less than two weeks repaired free of charge. GREAT SERVICE.
Unread 23-12-2010, 16:22
DonRotolo's Avatar
Back to humble
FRC #0832
Don, may I ask what they fixed?
Yes, you may.
Oh, you already did.
I don't have the details in front of me but they 'applied engineering fix #xxxx" something to do with the power system. A fuse could've been it, not sure.
Unread 23-12-2010, 16:31
Hmm. "Engineering fix" sounds like they didn't just replace with identical parts but rather upgraded something to address a known problem. Not that that's bad. It actually sounds like a good thing.
Unread 23-12-2010, 22:15
Morton,
As pointed out earlier, an RMA is needed for returns. The sooner the better as things will heat up after kickoff.
Unread 23-12-2010, 22:59
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Their number is:
(866) 511-6285
from 7 a.m. to 7 p.m. Central Time.
I got that from going to http://ni.com/first and clicking on the FRC logo.
-- Marshal Horn
Unread 23-12-2010, 23:21
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
My team had a problem last year with the cRIO getting zapped due to a faulty connection sending 12V through our chassis. It's unlikely that this happened to you, but it is a good reminder to insulate the cRIO.
Team 955
Raiderbot
Unread 27-12-2010, 09:19
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
We had the same issue with one of our spare CRIO's. It in fact was the fuse. This crio was being used on our practice robot. We did not have time to wait for the RMA process, which BTW is very fast, so I decided to repair it myself. I do NOT recommend attempting this yourself as it will most likely void any warranty and is certainly in violation of the rules. Since this unit was only being used on the practice bot it did not matter. After opening the cRIO and observing the blizzard of debris that fell to the floor, I located a small surface mount fuse (1206 apx.) located near the power connector. I do not remember the ref. designator of the fuse but it is F?. Using a multimeter I tested the continuity of the fuse and verified that is was open. I replaced the fuse with a 2 amp slow-blow in that same package. I reassembled the unit this time WITH the optional rubber gasket kit. The cRIO is now working fine.
Once agian I do not recommend doing this but we needed it now.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
cRIO not turning on!!! MHSrobotics2853 Electrical 14 18-02-2010 08:58
cRIO and Laptop Not Communicating ERROR CODE 63 bhavik15 Programming 7 27-01-2010 15:04
Not too much activity here... Kevin Thorp 3D Animation and Competition 20 27-01-2009 22:02
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
