Go to Post FIRST will work with you if you work with them. - R.C. [more]
Unread 23-12-2010, 10:04
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Wood robots
We have hooked up with a local company that makes large dies for cutting corrugate.
The will supply us material for free and laser cut whatever we want.
The plywood they use is high grade maple in 3/8" 1/2" and 5/8" thicknesses.
Looks like we will be building a wood robot
Anyone have any helpful tips and tricks for this kind of construction they would like to share?
Unread 23-12-2010, 10:53
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: Wood robots
Team 2471 has made a few robots that have been predominantly plywood. They may be able to offer some insight.
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: Wood robots
A couple of things come to immediately-
gusset, gusset, gusset everything.
RAGE, Team 173 is known for their wood drive bases. PM me and I'll send along contact info for their mentors.
Also, a few years ago I saw a team from Maine that built their complete robot from very high end plywood, I think it was 7 or 9 ply baltic plywood. I cannot remember the team number....anyone else??
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 23-12-2010, 10:58
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Wood robots
That would be the Riot Crew, FRC 58, from South Portland, ME. http://www.riotcrew.org/
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 23-12-2010, 11:31
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Wood robots
95 has made many wood chassis robots. We found the most robust way to attach the panels together was with bolts and 90deg angle aluminum. The angle brackets can be drilled on a drill press, clamped in place on the plywood, then just match-drilled through. Our recipe was 1/2" plywood with 1"x1"x1/8" angle brackets and 1/4-20 fasteners, CNSK heads on the outside for a nice smooth finish, and hex-heads with washers everywhere else. 3"-4" of space between each bolt, FWIW.
Have fun!
Edit: we also used the 7-layer baltic plywood, it is good stuff.
Unread 23-12-2010, 12:18
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Wood robots
If you are doing a plywood robot - "heck yea" on using baltic birch !!
Ed Barker
Unread 23-12-2010, 12:56
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Wood robots
Check with Jim, Team 1726...they make great wooden bots.
Unread 23-12-2010, 13:18
TestEngr571 TestEngr571 is offline
AKA: Dana Susca
FRC #0571 (Team Paragon #571)
Team Role: Electrical
TestEngr571 will become famous soon enough
Re: Wood robots
Team Paragon 571 has been thinking "inside the wooden box" for 10 years !!!
Unread 23-12-2010, 13:42
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Wood robots
Team 1771 created an excellent wood chassis.
http://www.chiefdelphi.com/media/photos/34907
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 23-12-2010, 13:51
Chris is me's Avatar
AKA: Pinecone
Re: Wood robots
1726 frames are awesome and a great inspiration to anyone making wood frames.
If you don't like cantilevering wheels, 1771 also makes fantastic rigid frames. I saw that thing in Atlanta and it was solid as a rock. Maybe a little heavy but with so much material the frame could take anything.
Baltic Birch!!!
Unread 23-12-2010, 14:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Wood robots
We only made one mostly wood robot, it worked well. We glued/stapled the main chassis structure, taking time to figure out how to make the thickness of the different parts so they'd be strong where needed, and light where we could get away with it, and also be able to attach the parts together--for example using thicker wood where staples needed to go into the edge.
Also baltic birch is strong, but it's kind of heavy, you might find that there are places in the robot where it would be better to use a less dense, thicker piece of plywood.
1771's construction method is really neat, with the interlocking tabs. Like an R/C airplane fuselage...
Unread 23-12-2010, 16:20
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Wood robots
I second the interlocking tabs.
My father (nor 92) owned a company that did die-cutting of cardboard. Back then, it was all hand-cut, but some of those dies are amazing.
For those unfamiliar, you first cut a thin line through plywood, then fill the space with a strip of razor steel "rule". Squish the finished die onto a piece of cardboard, and viola', you get cutouts. Think jigsaw puzzle. They used to get something like $10 an inch, decades ago. A typical 22 x 34 die might have 1000 inches of rule...
Consider using thin plywood with a fiberglass/epoxy coating where strength and low weight are a consideration. Do the math correctly, and wood can be pocketed like metal for weight savings without strength loss.
Unread 23-12-2010, 17:34
MrForbes's Avatar
AKA: Jim
Re: Wood robots
So that's how it works....I always pondered that while gazing at jigsaw puzzles. I was on the right track, but had never figured it all out, and never remembered to look it up when there wasn't a puzzle in front of me.
Unread 23-12-2010, 18:00
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Re: Wood robots
418 has done lots of work with wooden chassis and wheels. I personally have some experience with lightweight wooden boat construction. PM me if I can help in any way. a couple of years back we made a wooden chassis out of red oak (7 lbs) that is still knocking about as out promotion robot (should still be on CD someplace) and has had zero structural failures after many crash tests.
success is not hocus posus, it's focus focus
Unread 23-12-2010, 18:04
Onward through the fog.
Re: Wood robots
Is this it, Tony? I think this was the one made on a dare with members of the team, discussing the strength of wood.
Jane
~ Helen Keller
(1880-1968)
Stengthening Wood neoshaakti Technical Discussion 15 12-02-2009 16:21
Wood vs Aluminum ThomasP Technical Discussion 30 02-02-2007 23:48
Using Wood fredliu168 FIRST Tech Challenge 1 30-10-2006 21:46
pic: Wood as an David Brinza Extra Discussion 4 08-04-2006 19:29
Realistic Wood Corporat 3D Animation and Competition 6 07-02-2006 19:41
