Go to Post Ban the ingredients for cheesecake, and stores will find substitutes. Remove the market for them, and stores have no reason to make them. - Rachel Lim [more]
Unread 24-12-2010, 14:06
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: DS reliability
Originally Posted by Joe Ross View Post
There are a lot of things that can change when switching computers. Ethernet card, firewall, processor speed, background tasks, and operating system could all have an effect on the timing of the DS packets. For the test to be valid, you should run both versions of DS software on the same computer and compare the results. I assume it wouldn't be too hard for you to run the old DS software on your current computer.
That's a good idea.
I'll try to get to that on Sunday.
-- Marshal Horn
Unread 26-12-2010, 18:38
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: DS reliability
Joe, you're very right. I just did a test of the old driver station:
(I apologize, I forgot to show the histogram last time)
Do you have any suggestions for how I can have two versions of the DS installed on the same computer? This uninstalling and reinstalling is cumbersome for what should be a quick test.
EDIT:
Something seems funny about this data. The test took 2 minutes, not 2 hours.
EDIT2:
The data was correct, but my time elapsed calculation was not.
Here's a screenshot of another test of the same thing:
-- Marshal Horn
Unread 27-12-2010, 15:54
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: DS reliability
Just install the old version, save off the driver station .exe as a different name, then install the new version. You can then just run either one (one at a time).
-Joe
CAN reliability kamocat CAN 53 13-12-2010 00:35
Supershifter Encoder Reliability Problems? Qbranch General Forum 5 04-02-2008 12:55
2007 Radio link reliability problem Dave K. Control System 12 02-02-2007 22:26
Mechanical Reliability Andrew Blair Technical Discussion 20 26-10-2005 21:29
team 67 reliability? mattshuert OCCRA 6 02-12-2002 15:53
