Go to Post hmmm... big open space between arena and pits... thousands of poof balls...thousands of high school kids hopped up on sugar and robotics.... sounds a little dangerous. - Courtneyb1023 [more]
Unread 25-12-2010, 00:46
Chris is me's Avatar
AKA: Pinecone
Re: pic: 254 2010 Gearbox 4
I understand the use of the three position piston for the drive shifter; you need to throw it into neutral for the hanger to work... but why is the dog for the hanger a 3-position shift? Isn't their just "engaged" and "disengaged"?
Unread 25-12-2010, 00:54
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
It almost looks like there is gear engaged, neutral, and a lock because on the plate to the far right it looks like there is a dog cut into it.
Unread 25-12-2010, 03:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This is correct.
2001-2004: Team 100
2006-Present: Team 254
Unread 25-12-2010, 18:58
Jeff 801's Avatar
I am confused. Why there is a need for that lock when you have a pawl and ratchet on the shaft already?
Unread 25-12-2010, 19:38
NickE's Avatar
NickE NickE is offline
_
To lock the arm down before we deploy it. Otherwise it might bounce up while crossing a bump or getting hit.
pic: 254 2010 Gearbox 6 craigboez Extra Discussion 10 22-12-2010 22:13
254 Gearbox Analysis craigboez Technical Discussion 8 22-12-2010 09:17
Need specs to make 2010 FP Gearbox coupler ericzundel Motors 6 18-01-2010 18:20
pic: 254/968 Gearbox - Destructive Testing Results Travis Covington Technical Discussion 23 19-06-2007 14:58
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
