Go to Post "Why do it the easy way when you can do it the hard way?:rolleyes:" - EricH [more]
Unread 25-12-2010, 13:36
ErikRantapaa ErikRantapaa is offline
FRC #2532 (Flash Power)
ErikRantapaa is an unknown quantity at this point
Stop button needed?
I have the Driver Station up and running, but it reports "No Stop Button", and that message flashes when I click on "Enable".
So it appears that I need a Stop button. Is that right?
Unfortunately, I left the Stop Button at the school which is closed for the next week.
Is there an alternative? I have the ability to create a USB HID device that can return an arbitrary vendor and product id. Is there a solution along this approach? Is there a way I can map a joystick button to be the stop button?
Thanks!
Unread 25-12-2010, 13:43
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Stop button needed?
There is an alternative. If you double click on the stop button, it will give you the option to override it. I would not suggest doing this if you actually plan on moving the robot.
- Arizona North
You can bypass the Stop Button.
On the Driver station Diagnostics tab the stop button has an entry with a red light beside it.
Double click on the red light or text.
Unread 25-12-2010, 14:38
Thanks for the quick replies! I got it working now.
Unread 25-12-2010, 15:00
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Thanks!
They are correct, you can just bypass the stop button.
Regardless, I'll provide more info on what the stop button is:
It's not a joystick; it's a one-button USB keyboard. It presses the key command SHIFT-CTL-RETURN.
-- Marshal Horn
Unread 25-12-2010, 22:46
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Wait, are you serious? That's awesome. And potentially interesting...mwahaha?
GSR Dean's List Finalist 2011
Unread 26-12-2010, 00:57
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Yes.
How it distinguishes it from other keyboards, I do not know. It is PnP HID, not some unknown proprietary standard. (That's why it doesn't need additional software to work.)
-- Marshal Horn
Unread 26-12-2010, 20:48
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Wow, that's interesting, I've never heard this much about the Stop Button.
Can you buy and program these things?
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 26-12-2010, 21:29
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I believe you can, but they may only do large-quantity orders. http://www.smartbutton.com/
It's probably less expensive to just buy another stop button.
http://www.andymark.com/ProductDetai...Code=am%2D0515
-- Marshal Horn
Unread 03-01-2011, 18:56
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
Smile Re: Stop button needed?
Im sure you can find a "STOP" button from one of the many teams passing out buttons at various regionals. This way, you can pin it on your shirt, not lose it,and its free!
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 08-01-2011, 18:15
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Why? The spacebar acts as the same thing. In many cases the spacebar is better, because it doesn't require a physical reboot of the robot.
Unread 09-01-2011, 09:50
Gdeaver Gdeaver is offline
FRC #1640
It's curious how fast a human will disable safety devices Just because they are inconvenient.
Unread 09-01-2011, 23:07
Thanks for the info!
For those interested in creating their own stop buttons and are familiar with Atmel AVR microcontrollers, I'd suggest this site:
http://www.obdev.at/products/vusb/index.html
It is likely that the Driver Station detects the presence of the Stop button by looking for a USB device with a particular vendor & product id, but it also could be another mechanism.
Unread 10-01-2011, 01:47
FIRST incorporated a safety features into the DS, for good reason. An out-of-control robot is capable of causing quite a bit of damage to people and property.
If you construct a USB device that convinces the DS to enable the robot, please be sure that the device enhances safety rather than simply bypassing it. A button that DS and operator believe are an estop, but which launches a web page when pressed is actually more of a danger button, don't you think?
Almost by definition, all safety features are inconvenient at some point -- safety glasses, face shields, rotation guards, etc. In industry, there are usually procedures for operating without them, but all operators should be aware they are not in place and be aware of the additional risk and alternate safety mechanisms.
Greg McKaskle
E-Stop Button At Events ringo115 Control System 1 22-02-2010 21:29
Stop Button sportman3333333 Control System 3 21-02-2010 17:46
no stop button executionR Control System 1 20-02-2010 23:35
Emergency Stop Button Required? TangoBravo1318 Technical Discussion 13 02-03-2003 19:06
