Go to Post The trick is to train the rest of the team to blame electrical instead. - Al3+ [more]
Unread 26-12-2010, 22:00
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Ping ok, but still no Comms
The strange thing is the DS would only connect to the cRio if I had the wireless turned ON in my laptop!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 26-12-2010, 22:06
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Are you connecting through ethernet or through wireless?
-- Marshal Horn
Unread 26-12-2010, 22:32
Jon236's Avatar
AKA: Jon Mittelman
Wireless
Jon Mittelman
Unread 27-12-2010, 16:14
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
That sounds like the issue then.
You may have to disabled your ethernet port (or have it disconnected) in order for your DS to connect.
-- Marshal Horn
Unread 27-12-2010, 16:18
Jon236's Avatar
AKA: Jon Mittelman
But I was using the ethernet port to connect to the router. While I could ping the cRio with the wireless off, I needed to turn it back on for the DS to see the robot. Very strange!
Jon Mittelman
Unread 27-12-2010, 16:32
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
That means your DS was configured to use your wireless interface.
I don't recall how to switch it, but disabling your wireless might work. (If you're using Windows XP, this is done in the Network Interfaces part of the Control Panel; turning your wireless off on your laptop does not disable the interface.)
-- Marshal Horn
Unread 28-12-2010, 23:11
On last year's DS, the communications thread would lock in the DS IP address and the robot would need to be rebooted in order to change the DS to a new IP. Changing from wired to wireless NIC would typically use a new IP.
Greg McKaskle
Can ping CRIO and bridge, but DS shows no comm and no code Green2 FRC Control System 3 22-01-2010 23:55
Camera locks on but it still off dpick1055 Programming 3 18-02-2007 13:11
Not quite an animation, but still... Mazin 3D Animation and Competition 7 13-06-2006 22:25
pic: Tired but still fun at 3 a.m. on ship day! CD47-Bot Extra Discussion 6 27-02-2004 11:52
Team 108 Finishes, but is still confuzed Specialagentjim 3D Animation and Competition 2 20-03-2002 19:33
