Go to Post The more rookies the better, they always think of the things that we dont - pakrat [more]
Unread 26-12-2010, 08:08
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Ping ok, but still no Comms
Has anybody seen (and solved) the conundrum whereby you can wirelessly ping every part of the control system, including the cRio, yet the DS shows no robot communications?
I remember seeing a previous post that that was all the DS did to check comm status.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 26-12-2010, 13:42
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Ping ok, but still no Comms
I think pings are only used in the diagnostics screen, but the big section with "Robot Communications" means it is actively talking to the FRC_NetworkCommunication task on the cRIO.
Are you running NetConsole? Can you check if it is posting any errors?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 26-12-2010, 14:21
Jon236's Avatar
AKA: Jon Mittelman
Strangely enough, it began working after multiple reboots and resets.....so I'm still trying to figure out why!
Jon Mittelman
Unread 26-12-2010, 16:00
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
I think any trouble I've had with that has to do with multiple network interfaces; having both ethernet and wireless enabled, and the DS doesn't know which to choose.
-- Marshal Horn
Unread 26-12-2010, 22:00
Jon236's Avatar
AKA: Jon Mittelman
The strange thing is the DS would only connect to the cRio if I had the wireless turned ON in my laptop!
Jon Mittelman
Unread 26-12-2010, 22:06
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Are you connecting through ethernet or through wireless?
-- Marshal Horn
Unread 26-12-2010, 22:32
Jon236's Avatar
AKA: Jon Mittelman
Wireless
Jon Mittelman
Unread 27-12-2010, 16:14
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
That sounds like the issue then.
You may have to disabled your ethernet port (or have it disconnected) in order for your DS to connect.
-- Marshal Horn
Unread 27-12-2010, 16:18
Jon236's Avatar
AKA: Jon Mittelman
But I was using the ethernet port to connect to the router. While I could ping the cRio with the wireless off, I needed to turn it back on for the DS to see the robot. Very strange!
Jon Mittelman
Unread 27-12-2010, 16:32
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
That means your DS was configured to use your wireless interface.
I don't recall how to switch it, but disabling your wireless might work. (If you're using Windows XP, this is done in the Network Interfaces part of the Control Panel; turning your wireless off on your laptop does not disable the interface.)
-- Marshal Horn
Unread 28-12-2010, 23:11
On last year's DS, the communications thread would lock in the DS IP address and the robot would need to be rebooted in order to change the DS to a new IP. Changing from wired to wireless NIC would typically use a new IP.
Greg McKaskle
Can ping CRIO and bridge, but DS shows no comm and no code Green2 FRC Control System 3 22-01-2010 23:55
Camera locks on but it still off dpick1055 Programming 3 18-02-2007 13:11
Not quite an animation, but still... Mazin 3D Animation and Competition 7 13-06-2006 22:25
pic: Tired but still fun at 3 a.m. on ship day! CD47-Bot Extra Discussion 6 27-02-2004 11:52
Team 108 Finishes, but is still confuzed Specialagentjim 3D Animation and Competition 2 20-03-2002 19:33
