Go to Post "And that right there is the Sharpie line between right and wrong. Guess which side you cut on?" - Cypher [more]
Unread 27-12-2010, 09:19
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: cRio Power Light Not Turning on and no Activity
We had the same issue with one of our spare CRIO's. It in fact was the fuse. This crio was being used on our practice robot. We did not have time to wait for the RMA process, which BTW is very fast, so I decided to repair it myself. I do NOT recommend attempting this yourself as it will most likely void any warranty and is certainly in violation of the rules. Since this unit was only being used on the practice bot it did not matter. After opening the cRIO and observing the blizzard of debris that fell to the floor, I located a small surface mount fuse (1206 apx.) located near the power connector. I do not remember the ref. designator of the fuse but it is F?. Using a multimeter I tested the continuity of the fuse and verified that is was open. I replaced the fuse with a 2 amp slow-blow in that same package. I reassembled the unit this time WITH the optional rubber gasket kit. The cRIO is now working fine.
Once agian I do not recommend doing this but we needed it now.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
cRIO not turning on!!! MHSrobotics2853 Electrical 14 18-02-2010 08:58
cRIO and Laptop Not Communicating ERROR CODE 63 bhavik15 Programming 7 27-01-2010 15:04
Not too much activity here... Kevin Thorp 3D Animation and Competition 20 27-01-2009 22:02
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
