Go to Post Theres just something about a big honkin' robot that's irresistible. - seanwitte [more]
Unread 22-12-2010, 23:33
paper: joystick sensitivity (gain) adjustment
Thread created automatically to discuss a document in CD-Media.
joystick sensitivity (gain) adjustment by Ether
Unread 22-12-2010, 23:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: paper: joystick sensitivity (gain) adjustment
No dead band?
GitHub
Unread 23-12-2010, 06:24
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
I had fiddled with this off and on years before, but never really worked it out properly or had the time (or a spare robot) during build season. It's nice to see it formalized and posted here.
Just to make it clear (or correct me if I'm wrong), the X and Y are not the actual joystick numbers from the X and Y axis (eg, in y = x^3, axis x number doesn't produce axis y number), but the input and output from each direction, so really you should have two formulas:
AxisX_output = AxisX_input ^ 3
AxisY_output = AxisY_input ^ 3
The deadzone or band would be a separate calculation (at least programming-wise); a simple "if input is between -0.2 and +0.2 then Y= 0". Whilst doing it all at once would be elegant, it would be a nightmare to debug. Though looking at the graph for f(x)=x^3, in all practicallity the robot motors might not overcome robot weight at all under +/-0.3.
I wonder what the effect would be if a<0? That is, more power near zero (to overcome the robot weight) and leveling off at higher speeds.
In practice this would have to be adjusted to each individual robot; even similar robots (a prototype and competition robot for example) would have different results. Also adjust to the driver, as different drivers like different reactions. If the driver doesn't notice it, then it works!
Unread 23-12-2010, 07:39
Originally Posted by JesseK View Post
No dead band?
Not sure what you mean. You can easily add additional deadband if you wish, but for values of "a" near 1, you may not need to.
Unread 23-12-2010, 07:59
Correct. The X and Y are general variables. You can use this approach for any signal, not just the inputs from a joystick. For a 3-axis joystick, if you wanted to independently adjust the sensitivity for each axis, it would look like this:
X' = a1*X^3 + (1-a1)*X
Y' = a2*Y^3 + (1-a2)*Y
Z' = a3*Z^3 + (1-a3)*Z
...looking at the graph for f(x)=x^3, in all practicallity the robot motors might not overcome robot weight at all under +/-0.3.
Yes, at higher values of the "a" parameter, you may not need to add deadband.
Higher gain near zero, lower gain at higher commands. Not recommended under normal circumstances. See the added purple lines in the attached graph*. Also, you'd have to add logic to constrain the output to the range -1/+1.
Yes, that's the idea.
*for some reason this thread does not allow me to attach the graph
Unread 23-12-2010, 17:05
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We take a somewhat different approach.
We use four linear equations (y=mx+b). First, we test our robot. So far, every robot we have built has been skid-steer. This means that there is an appreciable amount of motor force that it takes to break the robot into a skid to turn. Utilizing a control on the dashboard, we watch the values required to break it free using only one side. This is the B-intercept of our equation, so that the instant you move the joysticks out of the controller's preprogrammed deadband, you have enough power to turn the robot at the slowest possible speed.
So we use one equation from 0 to about 80% power. This portion has a gentle slope. After that, the slope goes from that point up to 1 (maximum joystick), 1 (maximum motor output). The nice part is that we only need to enter two values into our custom VI. The "B" y-intercept value that the drivetrain manages to start turning the robot at, and the intersection point of the two slopes.
For instance, if you were to graph it, the positive domain of the joystick would have these x,y points:
(X,Y)
(0,0.2)
(0.7,0.7)
(1,1)
I'm trying to attach a picture, but it doesn't appear I can do so in this forum.
Unread 23-12-2010, 17:09
Does anybody know why this is, and can it be corrected? I also had the same problem: I wanted to attach a graph to a previous post in this thread but was not able to.
Unread 26-12-2010, 23:26
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
Really like the idea of that use of throttle.
Out of curiosity, is there anything special about the function x^3+x?
Recently we've used an exponential graph:
Let min = lowest desired value (min>0, usually the highest value at which the robot doesn't move)
Let max = highest desired value (usually, max = 1.0)
Then, output = min(max/min)^joystick value.
This also enables us to vary the max value for the turning axes based on the robot's forward speed.
Unread 27-12-2010, 10:12
Just to be clear (to avoid possibly confusing other readers), the function is not x^3+x, it is f(x) = a*x^3 + (1-a)*x. This function has some interesting properties.
As mentioned in the paper, when a=0, it becomes f(x)=x. When a=1, it becomes f(x)=x^3. When 0<a<1, it's something in-between. You can vary the "a" parameter to create a curve between f(x)=x and f(x)=x^3 to obtain the desired gain at low joystick settings.
Also, f(x) maps the domain (-1..1) into the range (-1..1) for any chosen value of "a" between 0 and 1, so there's no extra code required to break the domain up into, say, x<0 and x>0.
Clever. I like it.
If you want to add a Y-intercept to the f(x) function, you can do it like this:
g(x) = b + (1-b)*[a*x^3 + (1-a)*x]  for x>=0
g(x) = -b + (1-b)*[a*x^3 + (1-a)*x]  for x<0
Now you have 2 adjustable parameters: "b" and "a". The "a" parameter still adjusts the gain, and the extra parameter, "b", adjusts the y-intercept.
Interestingly, if you set b=0.2 and a=0.5, you get almost exactly the same curve as your exponential curve with min=0.2.
I have a graph prepared to illustrate this but can't attach it to this post for some reason*. I'll upload it when I get a chance.
Could you provide some more detail explaining what you mean please.
*if a moderator happens to be reading, would it be possible to change permissions on this thread to allow attaching graphs?
Unread 27-12-2010, 10:17
Nope! Pick anything that your drivers are comfortable with.
Selecting a joystick mapping function is one of the best teaching opportunities you have in FRC. There are many right answers, it is open to opinion, it is super easy to prototype, you can objectively compare a bunch of them on a whiteboard, and it answers the questions set forth in this article: http://www.fordham.edu/academics/pro...math/index.asp . That is to say, it might be the first time the students go in the "from problem to math" direction, instead of the "from math to problem" direction.
ax^3+(1-a)x does have a few special properties, see if your students come up with these in their lists of "wants" for their formula:
  • The function is smooth
  • The 1st derivative is smooth
  • It is tunable.
  • The gain is low near 0.
  • ...and high near 1.
  • The gain inflection is always near the middle (.577, per Ether)
Unread 27-12-2010, 13:36
FRC #0353 (Pobots)
@Ether
Cool, will try it with the y-intercept. Really curious if I'll be able to feel a significant difference at different a-values.
When I stated "This also enables us to vary the max value for the turning axes based on the robot's forward speed," I meant that we found at high speeds, a slight tap to the side on the joystick will send the robot flying away. So, for example, when the robot is moving 1.0 (full speed) in the y-direction, then we might only allow the robot to move up to 0.1 in the x-direction. When the robot isn't moving in the y-direction, then we allow the full 1.0 turning speed.
@EricVanWyk
As a student, steering curves was the first time I went from problem->math; it was definitely among my fav. robotics experiences. I will try this with some of the rookie programmers, and maybe my calc teacher
Unread 27-12-2010, 14:15
Well, that makes sense from a physical point of view. For those of us old enough to remember driving cars before the days of power steering, think how hard it was to turn the steering wheel when the car was not moving (like while parallel parking).
To address this problem, you could use the 2-parameter g(x) function, and treat the "b" inverse deadband parameter like a variable instead of a tuning constant. In other words, adjust the value of "b" (for the rotate axis conversion) as a function of speed before running your joystick rotate axis through the g(x) conversion. caveat emptor: I've never tried this.
Unread 27-12-2010, 15:49
(X,Y)
(0,0.2)
(0.7,0.7)
(1,1)
That's a good approach too.
I took the liberty of parameterizing it, to make it tunable on-the-fly.
Here's an implementation written in Delphi:
if (x>=a) then y := c+(x-a)*((1-c)/(1-a))
else if (x>=0) then y :=b + ((c-b)/a)*x
else if (x>=-a) then y := -b + ((c-b)/a)*x
else y:= -c + (x+a)*((1-c)/(1-a));
The above connects the points (-1,-1), (-a,-c), (0,-b), (0,b), (a,c), and (1,1) with straight line segments.
The three parameters are a, b, and c:
  • "b" is the y-intercept (inverse deadband), and
  • (a,c) are the coordinates of the point at which the slope changes
Unread 27-12-2010, 18:48
Originally Posted by EricVanWyk View Post
Thanks for that link Eric! I found myself saying "Yes!" out loud as I read it.
Unread 01-01-2011, 10:59
FRC #1153
Rookie Year: 1900
Yesterday I gave this to one of my programmers to put into our LabVIEW code, as a sort of a warm-up exercise. An added bonus was making it a sub-vi to plug into future code.
There is a difference in driving, though perhaps not enough to change a good driver with careful joystick control. We didn't test it fully however.
A suggetion that simplifies changing "a" from rewriting code to letting the driver change it on the fly: use the thumb-thingie on the KOP joystick (it's at the base in the front and is known as axis3). It's range is -1 to +1, but with simple math can be converted to 0 to +1.
Joystick Sensitivity furiousgeorge NI LabVIEW 15 04-02-2014 23:10
joystick sensitivity adjustment Ether Programming 3 19-02-2010 00:07
joystick sensitivity gabrielse Programming 2 08-02-2008 14:52
Joystick sensitivity Philz20 Programming 10 24-01-2008 08:34
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
