Go to Post Leave FIRST? That's an option? =) - treffk [more]
Unread 29-12-2010, 10:29
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Jaguar repair?
Originally Posted by ErikRantapaa View Post
They are gray jags.
Yes you can repair them depending on the severity and extent of the damage. However there are significant flaws with the gray Jags that IMO would make the effort required to repair them in vain. If your issue was with a black Jag I would suggest attempting to repair.
The gray Jags lack ESD protection, contain more FET's of higher Drain Source impedance and, if I remember correctly, significant board layout differences that effect heat dissipation. The current sense resistor is undersized and adds more series resistance to the bridge adding to the heat issue.
The black Jag contains ESD protection on all of the exposed pins, has a more robust layout, contains fewer FET's and has a high side current sense circuit that uses a 2mOhm current sense resistor of a higher watt rating. I have yet to ESD a black Jag, I have however ESD'd almost all of our gray Jags.
Even if you are able to repair your gray Jag you will most likely be repeating your efforts in the future.
Since your question was regarding repair, I will leave my interpretation of the legality for a different thread.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 01-01-2011, 22:14
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Jaguar repair?
Originally Posted by Alan Anderson View Post
I hope "tampering includes disassembling" was not intended to prohibit taking something apart if it was going to be reassembled in original working order before use. Note that teams are instructed to disassemble the cRIO in order to install the gaskets.
But one person's interpretation of "original working order" may differ from another's, and both may differ from the manufacturer's.
I am fairly certain that the disassembly of the cRio was a specific exception granted by FIRST.
My interpretation of the rule in general is along the lines of Al's comments above - you took it apart, it's really not OK to use it in competition. YMMV.
class mate repair / upgrade? George Control System 8 24-11-2010 18:43
Wheel Repair? AlexD744 Kit & Additional Hardware 9 18-02-2009 01:23
IR Board Repair AndrewSTA Electrical 3 12-02-2008 18:16
broken gamecube repair Kristian Calhoun Chit-Chat 7 26-11-2005 23:40
Repair Time After Reginals archiver 2000 10 23-06-2002 23:47
