Go to Post If I'm going to mentor someone, I'm going to be involved in their life as a positive force. - Mechvet [more]
Unread 29-12-2010, 20:26
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Re: on Mac
We are in the same boat as you. We are a "Mac only" school system. I nearly got run out of town when I asked for a Dell for robotics 5 years ago. We haven't found a work around yet either.
Unread 29-12-2010, 23:41
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: on Mac
Assuming you have intel-based Macs running 10.5 or later, you have two options:
Dual-boot (using Bootcamp)
OR a virtual machine (VMware Fusion, Parallels Desktop, etc.)
You can use a Virtual Machine on any intel-based Mac (that includes some machines running 10.4 ) , but Bootcamp wasn't introduced until OS 10.5.
-- Marshal Horn
Unread 30-12-2010, 01:42
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: on Mac
Hi. I have only used the Mac OS on a Virtual Machine, and not a lot with LabVIEW. Most cross platform implementations use the disable structure with the project "conditional disable symbols." Typically they would be placed around the DLLs or other platform specific code. Although, I suspect making wrappers for every vision VI that you use is probably going to be time consuming. You could try using the disable statement around the whole vision section and other problematic areas in your robot code.
Edit: Example posted:
Name:	Conditional Disable Diagram.png
Mike B
Unread 30-12-2010, 15:18
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: on Mac
I considered using VI Scripting to put disable structures around the CINs. However, I'm not familiar with how to place a structure around elements (I believe you have to place it down, move everything inside, and then fix broken wires). I also was uncertain of how to configure the conditional disable structure with scripting.
If there isn't a way to make dummy frameworks, I can just keep pressing "ignore" when LabVIEW searches for them.
-- Marshal Horn
Unread 30-12-2010, 19:48
SuperS_5's Avatar
FRC #1219
Re: on Mac
I have not played with scripting enough to give an example of that. I would put it around the code in your upper level VIs to keep life simple. If you really want to, you could just copy the whole library to your MAC side and go through all of the VIs to remove the offending code. (You could also use scripting for that) I don't recommend this though, as it makes it very difficult to upgrade/move. Any VIs connectors or references change between versions, it would cause broken code until everything is relinked. Modifying libraries are generally not recommended.
Mike B
Unread 31-12-2010, 10:11
Re: on Mac
Hi, my name is Greg, and I too use a Mac. I've been using since 1986, and I use numerous times a day. I hardly go a day without using.
If I'm loading FRC stuff, I typically just hit ignore a few times. I've never bothered building frameworks with the right entry points.
The other thing I do is to run parallels with Win7, LV, and other SW installed there. To keep the battery usage down, I typically have the VM paused. It only takes about five seconds to resume. Because the clipboard works transparently between the VM images, and one of the disks (Z) is mounted on Win7, I can pretty easily do everything I want. I still get stymied by networking sometimes. I end up going through the various Bridged and Host-Only settings until I find something that works.
Once upon a time, NI had a version of RT host for the mac, but there simply weren't enough purchases to justify the testing effort of the various protocols and configuration tools.
If you have any questions about the scripting, or any success, let me know. A slightly different approach would be to copy the VIs over to the Mac, and don't bother with the disable node, but instead, use scripting to delete the CLF nodes and remove bad wires. This will leave many of the VIs stubbed and returning defaults, similar to what you'd get if you disable the CLF.
Greg McKaskle
Unread 31-12-2010, 14:16
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: on Mac
Thanks, that answered my question. Building dummy frameworks isn't worth it.
I might delve into scripting sometime again (perhaps this summer?). It would be really nifty to find broken pieces of code (and drill down to the lowest level it can), and disable them.
However, your solution of just deleting the CLF nodes and FPGA invoke methods would probably be easier.
-- Marshal Horn
pc/mac nextvex IT / Communications 102 20-11-2006 22:04
Works on Mac? spears312 IT / Communications 8 12-01-2005 10:31
mac? AlbertW Chit-Chat 9 29-03-2003 21:01
Mac Programming tiskippy Programming 2 12-02-2003 00:08
