Go to Post It is better to err on the side of caution than to put yourself in a position to have a referee or judge make a call against you. Build smart! - Sean Schuff [more]
Unread 29-12-2010, 12:57
Chris is me's Avatar
AKA: Pinecone
Re: Possible new product Survey
I guess you could do it with an iPad / Classmate, but a lot of the stuff I use a strategy board for is for non-playbook strategies - drawing arrows between bots, scribbling out autonomous modes, et cetera. It would require a much higher investment than a marker and a handful of magnets to make software do what's being sought here.
Unread 29-12-2010, 13:06
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
For digital devices, a 'strategy book' is very straightforward. A simple graphic of the field with some software paint brushes would suffice to create strategies. One such program already comes with Windows, and in Win7 it's pretty darn nice to use with a touch surface. Saving the picture off is the hardest part (mostly because MS's operating system doesn't come with a default theme for larger buttons to be used by fingers...). I do this kind of thing all of the time for class with my Lenovo touch netbook.
Since the electronic device wouldn't be needed all of the time, it could stay in the pits on the charger. Yet I do agree that it's a $500 investment for something that's more of a toy than anything in regards to FRC; perhaps it's best to use this method only if someone already owns it and is willing to lend it.
Personally, given the choice I'd still rather have a 'board' and dry-erase; I have a phone with a camera and a real digital camera to 'save' the strategy off.
GitHub
Unread 29-12-2010, 13:14
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I'm with Chris on this one.
While a software option would be cool, it also means that you'd need some sort of touch screen device like a tablet PC, iPad, etc... That device would also need to be charged, needs time to setup, would be relatively fragile (in comparison to a clipboard) and is also just one more thing to have to keep an eye on.
A clipboard is great because it takes up minimal room, can be tossed on a cart, in a backpack, or just carried around and is pretty forgiving if you drop it, step on it, throw it, or attempt to use it for some other purpose other than a clipboard...
-Dustin Benedict
Unread 29-12-2010, 13:24
Originally Posted by davidthefat View Post
Oh I assumed due to the very low requirements for running such software that the classmate would have been sufficient to use.
That's likely a valid assumption, but I think there are other assumptions you're making that aren't nearly as good. When logged in as the Driver user, it doen't easily have the option of running arbitrary programs. The keyboard and trackpad are simply unsuited to such on-the-go use. Most importantly, though, the Classmate is needed for running the robot. It can't be taken from that task during strategy planning.
My team never did such planning, just talked it over with the alliance. My coach once told us that its not about the X's and O's but Bills and Joes. The coach can make all the best plays and the best strategies, but its really up to the players, driver for this situation, to pull it off.
I suggest that you take the opportunity to watch some of the "powerhouse" teams in action before their matches at the next competition you attend. Deciding on a strategic plan for each specific match is an important part of being an effective alliance. If you leave it up to the drivers to decide what to do, there won't be anywhere near the coordinated action necessary to play well against an alliance that does have an overall plan.
I don't know about you, but even with planning, everything goes up in the air once you actually start. Its so unpredictable during the game.
That's why it makes sense to establish strategic roles for each robot in advance. That way the drivers have a clear task to work on even in the middle of what seems like total chaos.
I mean, but if its boards that float your boat, go for it. I guess I am just the new generation that sees the boards as "old school" (Take no offense, like 20 years from now, kids will be laughing at our super computers)
If you want to spend your limited programming resources to reproduce on a computer what can easily be done better with a power-independent, larger, lighter, and cheaper whiteboard, that's up to you, but...
...Yeah, what he said.
Unread 29-12-2010, 13:57
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
That's a great idea, Adam! Hope it works out for you!
The Software idea seems a bit superfluous by the way.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 30-12-2010, 20:42
arob9119's Avatar
arob9119 arob9119 is offline
Ninja Munkee!
AKA: Alex Roberts
FRC #2395 (Ninja Munkees!)
arob9119 is on a distinguished road
I just took the survey.
That is a really great idea! I know my team would use one of those every meeting and almost all the time during the competition.
MUNKEES
(Misspelled on purpose)www.okcrobot.com
2012 Oklahoma Regional Winner
2012 Judges Award
Unread 30-12-2010, 21:36
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Originally Posted by JesseK View Post
... A simple graphic of the field with some software paint brushes would suffice to create strategies. ....
I tend to agree.
If someone wants to go the computerized route, the 5th Gear Simulator has had a "Show me a picture of the field" option for the last couple of years (it's not very popular; but we might take a little time to keep it alive again this season).
The 5th Gear option can be used by running 5th Gear during the tournament or by saving a screen shot ahead of time and using something like MS Paint or PowerPoint to sketch on top of it.
My preference was/is printing one of the field illustrations from FIRST (from the rules) on 11x17 and/or 8.5x11 paper and taking a stack of them, plus a clipboard, to the tournament.
However, an inexpensive clipboard might help you avoid looking like a dork when you drop the stack of papers as you try to juggle several hand-held items walking around the tournament or in a crowded pit area.
Blake
Blake
Unread 31-12-2010, 01:00
AKA: Pinecone
And a several hundred dollar touchscreen computer. I'd rather use a $15 whiteboard (which unlike paper is eraseable!)
Unread 31-12-2010, 01:13
kgzak's Avatar
kgzak kgzak is online now
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
we laminate a scale drawing of the field and attach it to an old a cookie sheet. We use scaled magnets to simulate max size of robots and it works out amazingly. we can draw on it with dry erase markers. Our team loves it.
Unread 31-12-2010, 09:28
DonRotolo's Avatar
Back to humble
FRC #0832
It doesn't have to. We develop a strategy that our alliance mates agree to - or they develop one we agree to - and we work the strategy as hard as we can. That got us an impressive record last year.
And other uses...
But they take forever to boot up!
Unread 31-12-2010, 10:04
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Possible new product Survey
just finished your survey, and hope it was helpful. because of our scouting other teams' capabilities, general strategy is usually discussed with partners well before we get into the que line. because of the fluid nature of the game once the match begins, it's up to the coaches to decide on changes. those decisions are most critical and ultimately can determine the outcome of a match. Strategy " boards" can go a long way in preparing for these changes.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 31-12-2010, 16:19
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Thanks everyone who has taken the survey. We really appreciate all the comments. We hope to provide an excellent product to robotic teams in the near future.
Stay Tuned.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 31-12-2010, 17:04
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
"Eraseable" is both a blessing and a curse. What I draw on the paper stays put when I tuck it under my arm or into a manilla folder or fold it in half.
There are at least two kinds of people in the world...
Blake
Unread 11-01-2011, 11:45
FRC #1405
Now that we have the game and all.
What type of field layout would you like to see on the boards?
Only the rack?
Half-Half, rack on top, top view on the bottom?
Rack on top with the tape lines, top view of field on bottom?
Others?
Unread 11-01-2011, 11:54
AKA: Pinecone
Every peg needs to be on the board somehow - I would say make it "flat" along the span of the 7 foot safe zone so they can be easily circled with a marker.
I feel bad - this is definitely a tough game to make a whiteboard for.
AndyMark's New Product? R.C. General Forum 3 16-12-2008 18:34
pic: Andymark's New Product R.C. Extra Discussion 30 10-10-2008 09:27
Possible New Team? DarkFlame145 Starting New Teams 10 25-03-2008 21:56
Possible new Regional for 2005 Rich Wong Rumor Mill 43 03-01-2005 08:18
Scientists uncover possible new species of human ... Katie Reynolds Math and Science 2 28-10-2004 07:09
