Go to Post Too bad MI isn't allowed to participate in FTC - Cory [more]
Unread 02-01-2011, 18:50
raytexans raytexans is offline
FRC #3778
raytexans will become famous soon enough
KOP Size??
We are trying to arrange for transportation to our kick off event and one of the things we have to take into account is how much space do we need for the KOP?
How much space will we need to transport it back?
Unread 02-01-2011, 18:54
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: KOP Size??
In the past, the KOP was distributed in two large totes, and a few small boxes.
You can fit it in the back of a van.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 02-01-2011, 18:56
FRC #3778
Re: KOP Size??
So if I was to take a mini van - I would have room for all 7 passengers and the kit?
Unread 02-01-2011, 18:59
Re: KOP Size??
Do you have a roof rack ? :-)
But seriously, what is the fore/aft cargo dimension behind the rear seat with the seat slid all the way forward and the seatback upright? This dimension varies among makes and models (eg Caravan vs Grand Caravan etc)
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: KOP Size??
from this thread a few years ago:
http://www.chiefdelphi.com/forums/sh...KOP+dimensions
The Kit of Parts contains: 2 totes (27"x17"x12" weighing 70lbs each), the robot controller kit (medium size box), drive train kit (medium size box), battery box (small - motorcycle battery) and a few envelopes.
I it hasn't changed much since I started 5 years ago. It might be a tad smaller given the new FIRST Choice ( I think that's the name) option this year.
Unread 02-01-2011, 19:10
Commander Canada
Re: KOP Size??
I know in 2009 we fit it all in a Pontiac Torrent, with five people in it.
-Nick
Unread 02-01-2011, 19:13
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
Re: KOP Size??
It should more then likely fit in most minivans. I have a Freestar, and I've fit more then 2 of those bins in the back, with the seating configured for max capacity.
I would just recommend that you bring any cargo nets if your van came with one. Plus having one where the back seat goes into the floor helps keep the gear secure.
Since it seems as if your getting a Rookie Kit, make sure that everything is secure espically with the crio and classmate in the bins/boxes.
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 02-01-2011, 19:17
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: KOP Size??
It would probably work, depending on the size of the trunk. However, if you can arrange it so that you can fold down the back row of seats to make the trunk larger and take fewer people, I would recommend that (better safe than sorry).
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 02-01-2011, 19:25
FRC #3778
Re: KOP Size??
The proposed van to use is a Grand Caravan with stow and go.
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: KOP Size??
It's bigger than a toaster oven, but smaller than a washing machine.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 02-01-2011, 19:34
Onward through the fog.
Re: KOP Size??
Just curious -
What Kick Off are you attending? And... how many adults are traveling with you? I would suggest that 2 cars go. The van and one other vehicle. That way, you are guaranteed room for the 7 passengers and the KoP. Andrew has provided the correct info regarding the KoP for rookie teams in this post.
Good luck in 2011 and let me know if I can help in any way!
Jane
~ Helen Keller
(1880-1968)
Last edited by JaneYoung : 02-01-2011 at 22:11. Reason: Andrew's tote information.
Unread 02-01-2011, 19:59
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Re: KOP Size??
we will probably be throwing our in the back of my Ford Explorer. I think you can find a way to fit it in to that van. from what I've seen in my dad's rentals, they have lots of room.
Unread 02-01-2011, 20:03
FRC #3778
Re: KOP Size??
We will be attending the Alamo Region Kick Off in San Antonio.
Being able to rent a van will save a a couple hundred dollars compared to what the school district transportation office wants to charge us for a bus.
Unread 02-01-2011, 20:19
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: KOP Size??
For any previous rookies, are there more than two totes? I have to pick up the kit for our team and my two options are my Subaru wagon with an open back seat (it can fit a tunnel robot from 2010 in the trunk with no seats down) and our 15 passenger gas guzzling van.
1058 PVC Pirates 2016 - xxxx
Unread 02-01-2011, 21:48
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Crusaders)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Re: KOP Size??
Since it is a Saturday, I would ask the team members to ask their parents. I know on our team we have ~25 students who go to the Hawaii Kickoff and we have about 6 parents who give rides -at 4:30 in the morning-. If even 1 parent can drop off and stay for 1 or 2 people you will be safe with transporting the KOP in the back of any Van.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST Hawaii Regional
-FIRST San Francisco Regional
School Size vs. Team Size Cyberphil General Forum 90 08-01-2011 20:03
KOP Jack Gillespie Pneumatics 3 31-01-2010 18:13
Size of KOP Crates JeffChan Kit & Additional Hardware 38 02-01-2009 14:49
Autodesk KOP Trackball - has anyone noticed that it's the wrong size? Tapoore CAD 1 17-01-2008 15:27
Wrong Size Trackball in KoP -- Rookie Team cjtenny General Forum 10 11-01-2008 23:07
