Go to Post Thanks for the heads up on the elevator game. - Andrew_L [more]
Unread 03-01-2011, 22:39
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Autodesk Award questions
We had a team meeting today. An idea came up that we could draw up our robot in Solidworks then export in to .STP or .STEP. By doing this it would allow us to pull it up in inventor and then exprt as an invertor file. I have a gut feeling this would be illigal, but if not would this be acceptable to do?
Unread 03-01-2011, 22:51
Re: Autodesk Award questions
First: What do the rules say about where the work needs to be done?
Second: This post on a similar but different matter may have some insight. Pay special attention to the second paragraph. No, this is not the rules. But the person making the post is reliable in this sort of thing.
Unread 04-01-2011, 09:07
384drtysteve101 384drtysteve101 is offline
FRC #0384 (Sparky)
384drtysteve101 has a little shameless behaviour in the past
Im am assuming you are entering in the 3d design contest
The rule for this award cleary states "If you enter in the 3D design category your entry MUST include use of at least Autodesk Inventor Professional 2011"
So technically you can do what you explained becasue you are making it on Solidworks then converting it over to Inventor. You would just have to construct part of it in Inventor, but none the less you still used Inventor 2011. But this wouldn't be in FIRST spirit, cause your entering Autodesk contest using Solidworks, which doesnt sound right at all.
No more Autodesk Visualization Award? Kevin Thorp 3D Animation and Competition 33 14-01-2010 21:04
Autodesk Visualization Award Golfer241 General Forum 6 03-02-2006 16:50
Autodesk Visualization Award haywirerobotics 3D Animation and Competition 18 30-01-2006 19:22
Autodesk Animation Award mhsrobot General Forum 5 20-11-2005 19:30
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
