Go to Post Don’t forget the purpose of Chiefdelphi. It is to keep the community connected and to help each other out. Moderators have been working days and nights to keep this forum going years after years. Let’s keep this place professional. - Arefin Bari [more]
Thread Tools Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Unread 04-01-2011, 02:59
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: LabVIEW PID uses derivative of Process Variable
You're right, that doesn't make sense.
Perhaps that error wasn't caught because people don't use very large coefficients for Derivative, and this VI is not very maintainable.
If the intent is to get rid of noise in the Setpoint (that is, variation in the Setpoint much faster than the mechanism can respond), then the 2nd derivative of the PV could be used.
-- Marshal Horn
Unread 04-01-2011, 08:00
Jared Russell's Avatar
Taking a year (mostly) off
It's not uncommon to use the derivative of the output (since the output is continuous, you don't have problems with step changes, and the output generally moves in a constant direction relative to the error). But the derivative of the PV doesn't make a lot of sense unless the VI was designed with a non-moving setpoint in mind.
Unread 04-01-2011, 08:30
I'll try to ask one of the authors or maintainers today. Skimming through Wikipedia on PID, it lists this along with integral windup as common modifications to the algorithm and state the same reason as Jared.
Greg McKaskle
Unread 05-01-2011, 10:48
abarp abarp is offline
abarp will become famous soon enough
Jared and Greg are correct. The modification is actually very common on industrial PIDs to avoid the 'derivative kick' from setpoint changes. In the literature, this is also called PI-D controller or even 2-Degree of Freedom PID. Here is some literature that could be useful in the future:
http://www.cds.caltech.edu/~murray/c...astrom-ch6.pdf
Unread 06-01-2011, 16:34
Greg McKaskle
Yes, and that would be me... Greg and Jared are correct about this feature. We use the derivative only from the measured variable to avoid the so called 'derivative kick' when you try to change its setpoint. This type of configuration is also called "PI-D controller" or "2 degree of freedom" PID.
Labview PID Gary Bonner NI LabVIEW 1 18-02-2010 20:31
Traction control: How do I tune a PID controller with variable gain? windell747 Programming 17 22-03-2009 21:18
How do i find a variable and use it on Labview Chris11246 NI LabVIEW 23 21-01-2009 17:50
Variable rollover with Labview (suggestions?) kamocat NI LabVIEW 7 22-08-2008 08:30
Two variable PID? I know someone's done it =)... Mr. Lim Programming 4 29-08-2006 00:31
