Go to Post You do know that totes are supposed to go through the chute right? Not humans? - themccannman [more]
Unread 20-10-2002, 00:53
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
RoboEmu 1.06 (works with XP and 2k)
Well, I'm surprised it ever worked under Win98 after fixing the problems. For some reason I forgot to allocate space for the \0 at the end of strings. I just added a +1 to the size and everything works just fine now.
I also cleaned up some of the new/delete stuff while I was sifting through memory, so it doesn't really leak any more.
Finally, WinXP will report an error a few seconds after RoboEmu closes. This is normal and is a known problem. It shouldn't really affect anything except making you click "Don't Send" (or "Send" if you feel like telling Microsoft about how XP causes more problems than its worth!).
Anyway, I tested under fresh installations of Win98SE, WinXP Pro, and Win2k Pro. I assume it will work fine with the "Home" editions also. Could anyone confirm this?
As always, I'd like to know what you like/don't like/think should be improved/features you'd like to see, etc.
Available at:
My website
-or-
The whitepapers section
