Go to Post I have yet to see an error where disabling the watchdog was the correct decision. - EricVanWyk [more]
Unread 04-01-2011, 17:22
Cody Trey's Avatar
Cody Trey Cody Trey is offline
Programing = hard + fun
FRC #2582 (Panther Bots)
Cody Trey is an unknown quantity at this point
Send a message via Yahoo to Cody Trey
Question c++ motor control
I need help controlling a jaguar using the Y-axis of a joystick. I am trying to complete code for last year's robot in c++ to have a working base to program on this year. I have most of my code done, if you'd like to see it just ask and i'll post, I can also post the error that wind river is giving me.
Thank you all in advanced!
Love, Peace, and Robot Grease
Unread 04-01-2011, 17:26
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: c++ motor control
I'm predicting no useful replies to this unless you post the error messages -- at least.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 04-01-2011, 18:34
Cody Trey's Avatar
My Code is:
#include "WPILib.h"
* This is a demo program showing the use of the RobotBase class.
* The SimpleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
class RobotDemo : public SimpleRobot
RobotDrive *myRobot; // robot drive system
Joystick *m_rollerstick;
DriverStation *ds; // driver station
Joystick *m_leftstick;
Joystick *m_rightstick;
Jaguar *RollerMotor;
Solenoid *Sol1;
Jaguar *rollermotor;
public:
RobotDemo(void)
ds = DriverStation::GetInstance();
myRobot = new RobotDrive(1, 2); // create robot drive base
m_leftstick = new Joystick(1); // create the joysticks
m_rightstick = new Joystick (2);
m_rollerstick = new Joystick (3);
RollerMotor = new Jaguar (3); // create the Jaguar for the roller
Compressor *c = new Compressor(4, 2); //creates the compressor object
c->Start(); //starts compressor
Sol1 = new Solenoid(1); // creates solenoid obects
GetWatchdog().SetExpiration(100);
* Drive left & right motors for 2 seconds then stop
void Autonomous(void)
GetWatchdog().SetEnabled(false);
myRobot->Drive(0.5, 0.0); // drive forwards half speed
Wait(2000); // for 2 seconds
myRobot->Drive(0.0, 0.0); // stop robot
Wait(2000);
myRobot->Drive (-0.5, 0.0); //drive backwards half speed
Wait(2000);
myRobot->Drive (0.0, 0.0);
Wait (2000);
* Runs the motors with tank steering.
void OperatorControl(void)
GetWatchdog().SetEnabled(true);
while (IsOperatorControl())
GetWatchdog().Feed();
myRobot->TankDrive(m_leftstick, m_rightstick); //sets the left and right joysticks to control the left and right motors
RollerMotor.Set( m_rollerstick.GetY() ); //sets joystick 3 y-axis to controll the roller motor
if (m_rollerstick->GetRawButton(4)) //gets button 4 from joystick 3 to control the soleniod on port 1, note: it is port one in the code, but is labeled port 0 on the hardware
{Sol1->Set(true);}
START_ROBOT_CLASS(RobotDemo);
the red section of code gives the error:
error: request for member `Set' in `((RobotDemo*)this)->RobotDemo::RollerMotor', which
is of non-class type `Jaguar*'
Unread 04-01-2011, 19:15
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
This is a shot in the dark from a die-hard C programmer who simply can't understand why people use C++.
Can you try this instead?
float foo = m_rollerstick.GetY();
RollerMotor.Set(foo); //sets joystick 3 y-axis to controll the roller motor
Unread 04-01-2011, 19:56
Cody Trey's Avatar
I just tried that, it seems that the error isn't in how i had it set up, it doesn't like something about the GetY and the Set, because its still returning the same errors. but it does separate the two errors into different lines which should make them easier to deal with.
errors:
GetY error:
error: request for member `GetY' in `((RobotDemo*)this)->RobotDemo::m_rollerstick',
which is of non-class type `Joystick*'
Set error:
Unread 04-01-2011, 19:58
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
It's a simple mistake. You need to replace RollerMotor.Set with RollerMotor->Set because you're using a pointer. Probably just a typo.
edit: same thing for the joystick error
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Oh, that's just because they're pointers.
Instead of m_rollerstick.GetY(), do m_rollerstick->GetY()
Same with the jaguar.
EDIT: Ninja!
GSR Dean's List Finalist 2011
Unread 04-01-2011, 20:11
Cody Trey's Avatar
YAY!! you guys are my heros! it worked, and i did the same motor.Set
Unread 04-01-2011, 20:33
Cody Trey's Avatar
Thumbs up Re: c++ motor control
Now tomorrow after final's I'll try to get it on the bot, i may be back with some more problems, but hopefully it will all go smoothly
Spike motor control kansattica NI LabVIEW 5 30-01-2012 11:37
encoder motor control pauldemonkey NI LabVIEW 1 19-02-2010 13:10
Motor Control Systems Astronouth7303 Programming 3 05-04-2005 19:35
Four motor control judson Programming 1 14-02-2005 20:17
Motor Control archiver 2000 1 23-06-2002 23:01
