Go to Post Now let's get back onto the original topic! :) - Calvin Hartley [more]
  #286   Spotlight this post!
Unread 04-01-2011, 20:41
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Re: 2011 FRC Game Hint #2
Originally Posted by SuperNerd256 View Post
Yes, but then you'd be stuck if you were in an alliance where you all specialized in the same thing. I don't think FIRST would want that.
So you mean like last year, when alliances were stuck if they had three frontfield bots?
Anyways, just like last year, you'd be operating at 1/3 efficiency. And it wouldn't happen in elimination if teams chose wisely. Probably the tasks would be similar enough that robots could reasonably do all three, but in order to excel at one they'd have to sacrifice efficiency on the other two.
  #287   Spotlight this post!
Unread 04-01-2011, 20:44
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
What if we're thinking to broad? what if its a hint to a piece in the Kit of Parts? I feel like they did that in a year past, can't remember though.
Anyway, what type of new part could be related to either of the hints?
"Don't worry, programming can fix it"
  #288   Spotlight this post!
Unread 04-01-2011, 20:55
Andrew Lawrence
Posts: n/a
But you forget. If you were tethered to a spot where you couldn't do anything, you'd be hopeless. If you were placed in a field last year that you didn't make your robot for, you could still succeed because you could push/kick the ball from wherever. Plus, you could travel over or through the tunnel to get to the side you needed. And if all else failed, you could ask your alliance members to let you go in the zone you wanted, unlike the "random" choosing of being tethered.
  #289   Spotlight this post!
Unread 04-01-2011, 20:56
2008, Game Hint 1 was an IR sensor sent to the teams. 2006, the game hint's original shape was sort of roundish like a ball.
In other years, it's been either vague or roundabout if it hit the KOP at all.
  #290   Spotlight this post!
Unread 04-01-2011, 21:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Now that we are 99% sue that it involves trains, we need to either find out what the trains can/will do, and if there are actual trains, or what the second hint means!
It won't involve trains.
  #291   Spotlight this post!
Unread 04-01-2011, 21:02
College...
I never said teams would be randomly assigned to a tether point, or that any part of the game field would be randomized. Remember, the GDC tries to encourage specialized designs that work together.
  #292   Spotlight this post!
Unread 04-01-2011, 21:03
Andrew Lawrence
Posts: n/a
I don't necessarily mean there will be actual trains, but an aspect related to them.
  #293   Spotlight this post!
Unread 04-01-2011, 21:04
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Locomotion was Little Eva's greatest hit, the logo is the 20th anniversary logo. Greatest hits from 20 years of FRC in one game!
1058 PVC Pirates 2016 - xxxx
  #294   Spotlight this post!
Unread 04-01-2011, 21:06
Andrew Lawrence
Posts: n/a
Then if you badly needed to be tethered to a spot you tell your team, and if they can work better than you in that position, then try your best somewhere else, and hope for the best. That's why you always need a backup plan. If you can't play on the spot you do best at, be sure you can at least compete somewhere else at least somewhat well.
  #295   Spotlight this post!
AKA: Bobby
Already covered earlier in the thread... multiple times. Besides, that really tells nothing of the game, only explains what has already be said, that it celebrates 20 years of FRC
  #296   Spotlight this post!
Unread 04-01-2011, 21:08
Andrew Lawrence
Posts: n/a
Though this has been mentioned countless times before,
It could mean that this game takes the best of the last 20 year's games, and puts them into one super-game.
  #297   Spotlight this post!
Unread 04-01-2011, 21:14
AKA: Brendan Browne
I know, I have read through every post in this thread and the 1st one. That is why I am certain that it has anything to do with locomotives after an afternoon of thought. You have to look at what I was replying too.
  #298   Spotlight this post!
Unread 04-01-2011, 21:15
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by TheoBlacksmith View Post
2. the FRC logo simply tells us that this is going to be a FRC competiiton
I just want to clarify, since I'm sure that someone else will make the same mistake somewhere along the line.
The triangle, circle, and square are not the FRC logo. Those shapes are also used in the FIRST, FLL, and FTC logos. What differentiates the different images is the text that appears underneath the shapes - which was left out of the hint.
That being said, we don't know exactly which logo this image is supposed to imply. It could mean that we will be utilizing elements from FLL and FTC, for all we know.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #299   Spotlight this post!
Unread 04-01-2011, 21:17
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
I agree. I think. Maybe.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
  #300   Spotlight this post!
Andrew Lawrence
Posts: n/a
That's new! It could be a FRC'd version of a previous FLL or FTC competition!
2011 Game Hint #1 ATannahill Rumor Mill 913 12-03-2011 19:26
pic: 2011 Game Hint #1 panterasFRC Extra Discussion 2 23-12-2010 00:52
2011 Game Hint FIRSTtm134 General Forum 4 01-12-2010 06:24
FRC Game Hint #4? finaldark Rumor Mill 59 04-01-2008 23:18
