Go to Post With all that chain call it Link and dress it up like Zelda. - nuggetsyl [more]
Unread 04-01-2011, 21:16
TNaylor TNaylor is offline
FRC #3777 (Team Robocalypse)
TNaylor is an unknown quantity at this point
Creo Elements/ProE Installation
I'm attempting to install Creo Elements with no success. I've downloaded the installer, run it, and got through most of the installation process. However, once it goes to the actual installation process, it hangs. I've attached an image of what my screen looks like. The picture changes periodically, but the progress does not appear to change. I've let it sit like this for 10+ mins with no change. Looking in my task manager, I can see no CPU utilization for either of the two PTC processes.
I've had the same results on two of my machines. One runs Vista (32-bit) and the other runs 7 (64-bit).
Any ideas?
Unread 04-01-2011, 21:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Creo Elements/ProE Installation
You need to use the full DVD image installation package. Their "online" installation package is broken. Did the same thing to me.
Unread 05-01-2011, 06:56
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Yes, use the full DVD download. I've installed it that way several times and have had no problems.
Unread 05-01-2011, 07:54
That was going to be my next approach. Thanks for the heads up!
ProE on Windows7 C3PO Pro ENGINEER / Creo 13 03-01-2011 14:47
ProE vs Inventor Pressondude CAD 5 24-05-2010 11:26
.stp to ProE ligerbots Pro ENGINEER / Creo 11 22-01-2010 14:52
Using ProE Erik Pro ENGINEER / Creo 10 26-02-2009 14:06
