Go to Post "You are the lead programmer now, therefore everything that goes wrong is your fault. When anything good happens its the teams fault." "But what if the robot spontaneously combusts?" "Your Fault." ~Borna - CodeTBone [more]
Unread 01-01-2011, 16:37
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
LabVIEW Numeric Controls
I've been struggling to figure out how to work with the "increment" property of numeric controls in LabVIEW. (By "increment" I mean the amount that the value changes when pressing the up and down arrows in the front panel.)
For example, I have a simple VI set up with numeric controls A and B. I want A to increment by "0.1", and B to increment by "10". When I go into properties and change the increment for A, A works fine. But when I then try to change the increment for B to "10", it instead changes A's increment to "10", and leaves B's increment as the default value of "1".
Anyone else struggle with this? Any ideas?
Unread 01-01-2011, 19:22
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
Re: LabVIEW Numeric Controls
Can you post your example VI with these issues so we can better understand what is going on?
Thanks,
Ryan
Unread 01-01-2011, 23:50
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
There are 2 ways to change the increment behavior.
1) Right click on control, and click on "properties." Change the options under the "Data Entry" Tab.
2) Use a property node. This is a advanced option, and you should understand the concept and limitations of property nodes before using them. If using them by references, (not directly linked) Then the behavior of what you see is possible when not implemented correctly.
If this did not help, please post example code as Ryan Gordon has already requested.
Mike B
Unread 05-01-2011, 11:13
I'm seeing the same behavior. It's as simple as putting two numeric controls on an empty front panel and then changing the increment value on the data entry tab in properties.
Unread 05-01-2011, 11:55
SuperS_5's Avatar
FRC #1219
Which version of LabVIEW are you using? I cannot reproduce this behavior.
Mike B
Unread 05-01-2011, 12:15
Known bug in the FRC 2010 version of LV (8.6.1) that has a patch that works fine.
A handy document to look for on the NI site is: LabVIEW 8.6.x Known Issues
When the new FRC LV edition arrives in the KOP I'd take the time to lookup the associated bug/issues list on the NI site.
Unread 05-01-2011, 13:31
SuperS_5's Avatar
FRC #1219
kudos. I tried it in the standard version.
Edit: Just realized that I already had this patch/version installed. Standard LabVIEW <=8.6.1 also has this problem.
Mike B
Unread 09-01-2011, 10:57
FRC #0353 (Pobots)
Mark--after setting up that patch, I get an "Executable version (8.6) doesn't match resource file (8.6). Check your configuration." message every time I run LabVIEW. Any thoughts? I'm still using the Breakaway version of LABView if that makes a difference.
Thanks!
Unread 09-01-2011, 12:14
Possibly one of the 3 (I think) files didn't replace what it was supposed to replace.
You might unzip the patch to your desktop, then copy each of the new files manually to where each is supposed to go.
When I installed the patch originally, I kept backups of each of the files being replaced so I could easily back out the patch if it caused problems.
When do you plan to install the new version?
Unread 09-01-2011, 14:01
FRC #0353 (Pobots)
Will install the new version monday--I guess that's partially why I was a bit careless and neglected to do the backup.
Tried to do it manually on my laptop and got it working, though. Thanks!
Unread 08-02-2011, 11:21
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
mine had the same error. i went in the patch folder and ran the .msi's and told them to repair now it works
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Lagging Controls RedHeadRobotics Control System 1 12-02-2010 12:04
usb numeric keypad mapping Arcre NI LabVIEW 3 09-02-2009 14:25
numeric AND kamocat Programming 4 27-10-2008 14:48
controls great_one411 General Forum 2 02-02-2003 01:03
controls nick_champ_2 General Forum 3 01-02-2003 20:21
