Re: LabVIEW Numeric Controls
kudos. I tried it in the standard version.
Edit: Just realized that I already had this patch/version installed. Standard LabVIEW <=8.6.1 also has this problem. Last edited by SuperS_5 : 05-01-2011 at 13:40. |
Mark--after setting up that patch, I get an "Executable version (8.6) doesn't match resource file (8.6). Check your configuration." message every time I run LabVIEW. Any thoughts? I'm still using the Breakaway version of LABView if that makes a difference.
Thanks! |
Possibly one of the 3 (I think) files didn't replace what it was supposed to replace.
You might unzip the patch to your desktop, then copy each of the new files manually to where each is supposed to go. When I installed the patch originally, I kept backups of each of the files being replaced so I could easily back out the patch if it caused problems. When do you plan to install the new version? |
Will install the new version monday--I guess that's partially why I was a bit careless and neglected to do the backup.
Tried to do it manually on my laptop and got it working, though. Thanks! |
mine had the same error. i went in the patch folder and ran the .msi's and told them to repair now it works
| Lagging Controls | RedHeadRobotics | Control System | 1 | 12-02-2010 12:04 |
| usb numeric keypad mapping | Arcre | NI LabVIEW | 3 | 09-02-2009 14:25 |
| numeric AND | kamocat | Programming | 4 | 27-10-2008 14:48 |
| controls | great_one411 | General Forum | 2 | 02-02-2003 01:03 |
| controls | nick_champ_2 | General Forum | 3 | 01-02-2003 20:21 |
