Go to Post Same as regrets in life: Learn from them. This is called "growth". - DonRotolo [more]
Unread 05-01-2011, 16:56
Data Nerd
FRC #0079
Re: 2011 Encrypted manuals are out.
Originally Posted by Alan Anderson View Post
Let's not.
Seriously, talk about cracking a password should not be welcome in this community.
Discussing doing it for malicious uses (such as gaining access to the game manual early) is not welcome. Discussions about the mathematics behind encryption is actually quite fascinating and I think should be encouraged. I would even go so far as to say that discussion of techniques for defeating encryption and why it is often not worth trying are incredibly useful.
Of course, if the mods disagree with this view please delete this post and let me know.
Unread 05-01-2011, 17:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The practicality of cracking the password is negligible. The passwords have historically been strong enough that unless someone uses a botnet there simply isn't enough time to crack it successfully before Saturday. 0-day hacks into Adobe as attempts to crack encrypted files have simply resulted in 0-day exploits for internet browsers instead of actually unencrypting the files, so I also doubt there are circumvention measures available.
In short: 128-bit SSL is still going strong, so don't get your hopes up of actually reading the contents before Saturday.
GitHub
Unread 05-01-2011, 17:10
Data Nerd
FRC #0079
Could you explain why? (Not saying you are wrong, just because I think it would make an interesting read)
Unread 05-01-2011, 17:14
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Originally Posted by nighterfighter View Post
If that were the case, you'd use roughly 12x less energy* time traveling into the future to find out the new game, and time traveling back.
*Assuming 1.21 gigawatts to travel through time one way, 2.42 gigawatts round trip.
Unread 05-01-2011, 17:31
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
I have a flux capacitor if someone can get the 2.42 gigawatts, and a Delorian, too.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 05-01-2011, 17:35
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
The Questions is, do we attempt to build a Mr.Fusion, or do we go for the Plutonium from the Libyans?
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 05-01-2011, 17:36
Neither. We go for the lightning bolt.
Unread 05-01-2011, 17:50
GW Kalrod GW Kalrod is offline
AKA: Nick Plante
FRC #0166 (Chop Shop)
GW Kalrod is an unknown quantity at this point
Send a message via AIM to GW Kalrod
128-bit encryption means 128 bits.
The number of permutations is 2^128, or 340282366920938000000000000000000000000 possible permutations.
Even with really fast processors, it would take months to brute force that. Assuming you don't really have access to some kind of supercomputer or massive distributed computing network.
Although a few recent papers have called into question the security. AES-128 encryption. If you like technical stuff, here:
http://eprint.iacr.org/2009/374.pdf
Although they conclude the encryption is fairly secure at this time, some flaws have started to appear.
KISS (otherwise known as the easiest way to not win.)
Unread 05-01-2011, 18:26
pfreivald's Avatar
AKA: Patrick Freivald
It's something I've worried about since "DriveFastTurnLeft"... If the passwords were random strings of alphanumerics, then they'd be for all intents and purposes impossible to crack in the time frame -- but game hints combined with cribbed passwords, that's just bad cryptology right there!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 05-01-2011, 18:28
Andy Grady Andy Grady is offline
I'm done being quiet!
FRC #0131
Rookie Year: 1995
Andy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond repute
Send a message via AIM to Andy Grady
Here is a question regarding NOT cracking the code..
I am new to the Mac universe, I am trying to download and save the files to my computer and open them with adobe which i have just downloaded. Instead of being successful, it says that the files are damaged and I don't even get the prompt for the password. Anyone with a Mac have a tip or two?
Help would be appreciated.
Unread 05-01-2011, 18:29
Data Nerd
FRC #0079
Just use the default Preview.app instead of the Adobe one. I never had a problem in the past. You could also try redownloading as they may actually have been downloaded corrupt (it happens).
Unread 05-01-2011, 19:03
FRC #0131
Rookie Year: 1995
Got it! Thanks! Computer was being temperamental.
Unread 05-01-2011, 19:04
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
this happened to me (albeit on Windows), after downloading and renaming the file. I tried again, this time not renaming the PDF (keeping it as Complete_FRC_Game_Manual_05Jan2011.pdf) and it worked fine.
Unread 05-01-2011, 20:03
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Uhh...the passwords aren't usually just alpha. "Drive!Straight?turn.LEFT!?" is a good example. Punctuation adds a little more complexity
"Breakaway4FRC" was "simpler", but would still take a while to bruteforce.
I'm wondering if anyone's just run a bruteforcer during build season to see how long it would actually take...
GSR Dean's List Finalist 2011
Unread 05-01-2011, 20:15
Joe Schornak's Avatar
Joe Schornak Joe Schornak is offline
No Stranger To Love
FRC #2840 (Blue Tide)
Joe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to behold
On another note:
Does anyone else find it significant that the decryption test file features our favorite picture of our favorite singer? Perhaps FIRST is trying to tell us something more about that hint...
Or perhaps they're just messing with our minds.
1. Acquire Manual
2. Read Manual
3. ???
4. PROFIT!
Visit www.pcdsrobotics.org!
paper: 2011 Regionals/Districts Teams are Attending Ed Law Extra Discussion 5 27-12-2010 14:26
Division are out Matt_Kaplan1902 Championship Event 21 11-04-2004 21:07
Encrypted Rules are now available Mark McLeod General Forum 24 11-01-2004 00:18
Divisions are out!! Joel J Championship Event 55 06-04-2003 01:34
Belts are out Wheels are in? Kevin Ray General Forum 18 16-03-2003 18:46
