Go to Post Magic doesn't count as a support, sorry. Neither does simply constraining in CAD... - EricH [more]
Unread 06-01-2011, 00:06
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Cloud Computing: A Reasonable Solution For The Build Season?
Now, personally when I first heard about this "cloud computing craze", I thought it was a load of bull. I thought big corporations just want to take over the internetz. Now after thinking about it, I have been flirting with the idea of having a private "cloud" for our team. We have a lot of programmers this year (8+) and I have yet to think of a feasible and practical solution for code management. Then the "cloud" came to me. Personally, I use google docs all the time and I think its just great. All I am doing is school essays and stuff like that, nothing top secret, so I wouldn't care if Google has all those documents on servers. I been thinking of setting up a server running Ubuntu Server. It can be used for everything from code repository to CAD storage and meeting notes. Now I certainly believe in distributed computing; just look at folding@home.
Now I want to know if I am misunderstanding or misinterpreting what cloud computing really is.
Do you think its a good idea to set up a Ubuntu Server Cloud? It only takes 2 hours max of downloading, burning and installing.
What does it take to maintain a "cloud"?
Are any other teams considering it?
Is my idea even feasible?
Unread 06-01-2011, 00:19
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Cloud Computing: A Reasonable Solution For The Build Season?
Im a bit confused as to why you would want a personal cloud (besides the awesome factor). It seems that with Google Wave (if you don't have it, then why not!) that is exactly what you are asking for. It's perfect for communicating ideas around, and although not top secret, I doubt Google with disseminate your ideas to other teams.
Cloud computing, is also more for distributing the load of something: Amazon distributes the load of servers, F@H, I guess is technically a cloud. Unless you are doing so ridiculously heavy compiling, then I doubt you need one. It should also be noted that the term "cloud" computing defies having a personal one XD
Unread 06-01-2011, 00:42
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
For code management, there are already several tools widely used such as git and svn. It isn't hard to set up a local repository. If you want to store your code off site, you could use a free service such as github.com. For general "office" documents, google docs works pretty well. If it aint broke, why fix it?
There are many resources already available. There is no need to reinvent the wheel.
Unread 06-01-2011, 00:59
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Eh, I guess I'll just go with the old fashioned server and repository. I set up servers before so I guess I am fine. Now I have to find a way to coordinate everyone working on the same project. Its like the parallel processing problems: deadlocks.
Unread 06-01-2011, 02:09
foote stepped in
AKA: E. Foote
FRC #0868
In 2007 another programmer and I set up an SVN server on his personal web server, and saved the code that way. Unfortunately, some of the lesser experienced programmers dumped their code in mid-season. One second everything was compiling fine, the next we had 100ish errors, 500 warnings, and a headache. It took us 20 minutes to realize what had happened, after that they had their own "special" repository set up.
Version control is great for teams of people, just make sure everyone knows what they're doing. Giving read access to files is great, allowing people to modify and write files haphazardly is not.
Last thing - keep in mind that keeping version control takes discipline - if you don't religiously update and save the latest version of code, you might as well not take the time to set it up.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 06-01-2011, 03:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
For simple sharing of files, you may want to look into Dropbox.
Unread 06-01-2011, 06:47
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Dropbox and other online storage is useful, but only if you have many people working from home. If most work is done locally, a local server (which is what we have set up) works quite well enough. I'm not much of a programmer, but version control doesn't have to be online either. If you already have a server set up, you seem to be well prepared already.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
FIRST/ Build Season for Dummies Carlee10 Chit-Chat 3 26-04-2008 19:02
Build Season in the Classroom MasterChief 573 General Forum 25 28-02-2008 07:32
Any teams build two robots to practice with after build season. (6 weeks) GVDrummer General Forum 42 24-01-2008 21:34
Food for thought as build season goes on JoeXIII'007 Chit-Chat 1 09-01-2008 14:58
Bad Jokes For Build Season JohnBoucher Chit-Chat 11 31-01-2005 02:32
