Go to Post We could not make weight so we got rid of the cRIO. - Mike Copioli [more]
Unread 01-06-2011, 12:18 AM
Mcninch's Avatar
Mcninch Mcninch is offline
Mcninch is an unknown quantity at this point
What do you know about OBD-II?
Reading up on some gadget news today, I read that all cars manufactured since 2000 have OBD-II installed beneath the dashboard, which enables it to communicate with gadgets such as the ‘AutoBot’ (tracks your car) and CarTrip (stores your car data on an iPhone). I was wondering who has actually experience with using the OBD-II with these or similar gadgets? Sounds interesting..!
Good Luck!
Unread 01-06-2011, 01:34 AM
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: What do you know about OBD-II?
Acctually, since 1996 they've had OBD-II.
It is what your mechanic uses when they connect a diagnostic scanner. Essentially, anything your car's computer knows is available through it.
If you are interested you should talk to your auto shop instructor.
Eric Haskins KC9JVH
Unread 01-06-2011, 03:45 AM
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
I haven't actually played around with it myself, but NerdKits has a tutorial on interfacing electronics with the OBD-II in your car. http://www.nerdkits.com/videos/obdii/
It would probably make a pretty awesome project... for after build season of course
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 01-07-2011, 11:14 AM
Matt Howard's Avatar
Matt Howard Matt Howard is offline
Submarine Sailor
FRC #1622 (Spyder)
Matt Howard has a spectacular aura aboutMatt Howard has a spectacular aura aboutMatt Howard has a spectacular aura about
OBD is good for Diagnosing problems, but that's about it. Without high $$ hardware, you cant do much else with it.
-2010 Las Vegas Regional Judges Award
-2010 Las Vegas Regional Safety Award
-2010 San Diego Regional GM Industrial Design Award
-2010 San Diego Regional Excellence in Design Award
Unread 01-10-2011, 03:46 PM
Prelude_SH's Avatar
Prelude_SH Prelude_SH is offline
Yes sauce
FRC #1742 (Shockwave)
Team Role: Student
Prelude_SH is an unknown quantity at this point
OBDII is for diagnosing CEL, SRS, etc. codes.
Easy to pull, at least on my car. the dashboard flashes all the lights in a certain series depending on the problem.
Unread 01-10-2011, 10:35 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Just avoid causing damage to that very expen$ive engine control unit...
I disagree.
Yes, you can read out the On-Board Diagnostic (OBD) fault codes, which can help in diagnosing the problem. But there is a wealth of vehicle operational data available on that connector, such as fuel economy, vehicle speed, and more.
Inexpensive (<$100) testers are readily available.
The "high $$ hardware" are manufacturer systems, which work on every system in the car (like A/C, seats, locks, etc.), not just the emissions-relevant ones covered by the OBD laws.
As for the original post: There is a LOT of info on the web about OBD II, since it's a publicly-documented system. The OBD connector is under the dash, but the 'computer' behind it can be located anywhere.
Unread 01-11-2011, 01:05 AM
Submarine Sailor
FRC #1622 (Spyder)
We're thinking on two different wavelengths here. By diagnosis I was encompassing everything you stated.
The the expensive tools I am thinking of, are for performance programming. Fuel maps, engine management, timing advancement, 02 Delete, disabling emissions control devices, things of that nature.
Unread 01-11-2011, 02:24 AM
Mcninch's Avatar
Thanks guys! I appreciate your very informative replies.
Good Luck!
Unread 01-25-2011, 01:23 PM
Tobot Tobot is offline
AKA: Toby
FRC #1827 (Robojackets)
Tobot is just really niceTobot is just really niceTobot is just really niceTobot is just really nice
I've been using an Ultragauge for about 6 months. I have been really pleased with it. It helped me push my average fuel economy in my car over 50 mpg.
Some of the newer cars report over 70 sensor outputs through OBD-II. It's a pretty rich data stream.
Unread 01-26-2011, 03:00 PM
Submarine Sailor
FRC #1622 (Spyder)
A Vacuum gauge is all you need to hypermile. That tool is simply a detuned codepuller.
Unread 02-02-2011, 10:14 AM
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
OBD-II comunicates via can right?
Hook a black jag into it and read the data from the serial end of the jag.
Use the jag later to build a robot or
use the jag to use your car as the robot
Win-Win-Win
(Hopefully) All you need to know about Pneumatics RyanN Pneumatics 6 02-25-2010 05:22 PM
You know what sucks? Mr. Lim Programming 14 02-19-2005 04:25 PM
what do i need to know about drive trains angier314 Motors 1 01-16-2003 12:43 PM
what do you know about high school robotics scholarships angier314 Chit-Chat 1 12-14-2002 11:59 AM
