Go to Post Fame is a funny thing, you can do nothing and get it, and do everything and get none. For me, it's not fame, but infamy that follows me. - Joe Matt [more]
  #33   Spotlight this post!
Unread 06-01-2011, 11:35
Re: Modeling motor control
Neither controller provides a discharge path during the OFF period. It is this phenomena that gives the Jag it's apparent linear response.
The FETs in both the Tan and the Black Jags have a zener diode to provide a path for the current to keep flowing through the motor during the OFF portion of the cycle.
http://www.chiefdelphi.com/forums/sh...30&postcount=9
The Jag's linear response is due to its higher switching frequency, which creates an effectively flatline current waveform whose amplitude (which is the average since the wave is flat) varies linearly with the voltage duty cycle.
The Vic's slow switching frequency allows to current to decay to zero during the off portion. The average value of this sawtooth waveform does not vary linearly with the voltage duty cycle, so neither does the motor torque.
Encoder Motor Control Wicked NI LabVIEW 3 11-02-2009 18:21
Motor control problem Lablabla Programming 3 17-01-2007 15:27
Motor Control Systems Astronouth7303 Programming 3 05-04-2005 19:35
Four motor control judson Programming 1 14-02-2005 20:17
Motor Control archiver 2000 1 23-06-2002 23:01
