Go to Post I have never seen a coach with a better ability to yell with love. - IndySam [more]
Unread 16-12-2010, 19:48
BrandonG's Avatar
BrandonG BrandonG is offline
IRC Junkie
FRC #2865 (Roboteknix)
BrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of light
cRIO getting wrong IP after reimaging
So we are reusing last years cRIO and I am trying to teach the new members how to reimage the cRIO. The imaging tool works perfectly fine except that it sets the cRIO's IP to 10.0.0.1. I entered our team number into the correct box but it isn't setting it. I searched the forums but found nothing. Anyone else have this problem?
www.roboteknix.com
Originally Posted by A bum in Atlanta
if you was my sister I'd mug you
If anyone uses IRC, pm me and let me know what networks, I have never heard of anyone in FRC using IRC besides me O_o
Unread 16-12-2010, 19:50
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: cRIO getting wrong IP after reimaging
Is the IP RESET switch on the cRIO flipped?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 17-12-2010, 02:32
BrandonG's Avatar
IRC Junkie
It's off when I try to reimage it, I've gone through ip reset procedures a couple times and it resets it. Still doesn't receive the right ip from reimaging ):
www.roboteknix.com
Unread 17-12-2010, 20:35
AKA: Ian Thompson
I'm not sure exactly how the IPs work in port 2, but is there any chance you've accidentally connected into ethernet port 2?
Unread 18-12-2010, 09:03
Port IP is set via MAX, the Measurement and Automation eXplorer. You shouldn't really need to change it from what the image sets it to.
Greg McKaskle
Unread 18-12-2010, 11:41
Grasping at straws here -- what computer are you using to do the imaging? Do you have it connected to the cRIO directly, or through a router? The Classmate has trouble when directly-connected, when the cRIO's ethernet port gets reconfigured during the format and re-image process, and re-establishing the physical network link on the Classmate side of the wire takes longer than the software is prepared to wait. Other computers might have the same problem. If you aren't using a router, try adding one.
Unread 18-12-2010, 23:48
BrandonG's Avatar
IRC Junkie
Yep, port1
Using a dell laptop (we've used it before to do this)
Tried the following:
- straight
- crossover
- through router
same thing every time D:
www.roboteknix.com
Unread 19-12-2010, 07:18
The existing imaging process moves the cRIO from IP to IP as part of the process. If the networking isn't simplified, it is pretty for the laptop to be unable to locate it at one of the intermediate IPs.
Make sure that any secondary NICs are turned off, including wifi.
Greg McKaskle
Unread 06-01-2011, 17:19
BrandonG's Avatar
IRC Junkie
Yep, wifi is disabled and the laptop only has one ethernet port. Trying it again to see If I have better luck this time, if not I will record a video of what I am doing and upload it to youtube.
www.roboteknix.com
Unread 06-01-2011, 18:25
BrandonG's Avatar
IRC Junkie
It works now... just kept going through the reflashing process over and over and eventually It came back with the correct IP.
EDIT: NVM, it wont give it the custom name, if I try to use a custom name, it gives me an error after it tries. Oh well, I guess it is okay that it is named temp -_-
www.roboteknix.com
cRIO reimaging pains slavik262 FRC Control System 13 13-02-2011 07:05
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Problems reimaging cRIO ravena Technical Discussion 13 17-02-2009 20:19
Help Getting cRIO Feedback rholokleolke C/C++ 3 29-01-2009 17:13
cRIO interrupted during reimaging rsisk FRC Control System 23 21-12-2008 22:41
