Go to Post resist the hive: As goofy as this may sound, wires do take up weight, several pounds of it. - Rickertsen2 [more]
Unread 06-01-2011, 18:50
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
altitude sensors anyone?
for the collegiate first pilot program we would really like a way to be able to tell the altitude of our quadcopter. since i dont to trust GPS signals inside a building and i don't know of any altimeters that work at this low of an altitude, does anyone know of a good distance measuring sensor?
We're looking at measuring distances of up to 10m and to be accurate within about 6 inches or so. all of the sonic range finders i'm familiar with do not have a large enough range. the rules state that we're not allowed to have lasers of any kind, so that throws out laser range finders.
706's Logomotion Bot:
http://www.youtube.com/watch?v=bP7UL...layer_embedded
2010 Breakaway Bot:
http://www.youtube.com/watch?v=pV2V9Kgzhrc
Unread 06-01-2011, 19:11
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: altitude sensors anyone?
You're correct that altimeters are nowhere near accurate enough.
I would recommend a MaxBotix SONAR sensor.
I'm guessing you want the narrow beam width, but it may take some testing to find out.
maxbotix.com
-- Marshal Horn
Unread 06-01-2011, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
The Maxbotix I have is limited to about 255 inches.
But surely other types have the range; perhaps laser-based.
Unread 06-01-2011, 23:43
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
How high in the air are you? 252 inches is 21 feet.
With a laser-based sensor, you'll have to do some processing to deal with the noise in your reading (because you're measuring distance in a straight line, and there's ALWAYS clutter on the ground)
EDIT:
I suppose the other option is to use the ground-based vehicle as a distance reference. You can triangulate.
(To be honest, time-based methods with light are a pain to measure because it's such a minuscule length of time)
-- Marshal Horn
Unread 06-01-2011, 23:48
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Whats the size of this aircraft, and what are it's processing capabilities? I've been told that with a little filtering and math on the inputs, it's possible to properly extend the Maxbotix sensors out to well over 100 feet if using more than 1.
Attending: MN Duluth Regional
Unread 07-01-2011, 04:02
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Tried a camera? One of my mentors has this quadcopter that uses a camera point directly down to stabilize itself or something. So I guess if it uses edge detection to find the edges. It can find out if they moved or something.
Unread 07-01-2011, 09:03
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Kinect? (http://www.youtube.com/watch?v=4EGQZ...eature=related)
Failing that, maybe a poor man's kinect? Maybe with a strong IR emitter on the bottom and an IR sensor, you could determine from the brightness of the received IR how far away from the ground you are. This would depend on how much the ground below absorbs IR so it might not work if you don't know what you'll be flying above.
Unread 07-01-2011, 12:39
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Is it possible to change your competition strategy? i.e., since you are indoors, fly closer to the ceiling and monitor your clearance to the ceiling itself.
What exactly is your motivation behind wanting to get your range at that far away? Their may be ways around this limitation, depending on your reasons. And since it is an indoors environment, are you able to place static objects ahead of time? Probably not, but it's a thought.
Unread 07-01-2011, 13:14
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
The collegiate FIRST pilot is happening at championships. The field will be very similar to the FRC field, and will have a net over it (if I remember correctly). Though definitely a fantastic new way of looking at the problem, that won't work.
As for other suggestions- Kinect would be so much fun, but these are light quadrocopters (powered by arduinos), so I have a feeling that would be too heavy.
The other problem here is that there are platforms that robots must land on, so I am not sure how much help sonar will be. Not exactly sure what the altitude will be used for, but this may cause an issue.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 07-01-2011, 13:27
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
For a sonar or light-based ranging system, I would recommend a Kalman filter strategy for error/noise rejection.
If you want to get fancier, add 6-axis inertial measurement unit along with the ranging system, and tie it all together with a Kalman algorithm strategy. This can work quite well.
Unread 07-01-2011, 17:20
Alumni
AKA: Ken Condon
thanks for all the help
so first of all, i think it's especially important to mention that we're using 2 controllers. one processor for controls and one for fancy sensor inputs (image analysis and whatever else we throw on there). the second processor may be an ARM 3530, so i think kalman filters on the matbotix sonic rangers will do the trick. After reviewing the rules, i found out that the ceiling is 16 feet high, so that should be within the 255 in range of the range finder.
i was going to play around with using the camera and an optical flow algorithm to do position hold, but unless you're looking at a fixed object on the ground with a known size and shape, you cannot use the camera to determine altitude.
2010 Breakaway Bot:
Unread 07-01-2011, 18:48
Gdeaver Gdeaver is offline
FRC #1640
There are some high resolution pressure sensors available. With the proper calibration you might get 1 foot accuracy. Turbulence with a copter could be the killer. A tube with properly designed holes may help. They use SPI or I2C so the audrino low analog is not a n issue.
Unread 07-01-2011, 23:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The maxbotix sensors are accurate over long distances (VERY accurate) but only if they are held still. They also have a noticeable lag time along with an overshoot-then-leveling-off issue when used with the analog (I'm not sure if the digital connection has the same problem).
I would consider combining two sensors. The ultrasonic for longer distances and the sharp for closer in where speed is important.
Sharp does have some longer range rangefinders (1.5m) that might work:
http://www.robotshop.com/sharp-gp2y0... campaign=jos
Unread 08-01-2011, 17:43
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I have found that using the measuring the digital pulse on the Maxbotix SONAR is much less noisy than the analog signal. (It also doesn't have the trouble with maximum slew rate).
Granted, this is with FRC hardware. The characteristics of your control system will be different. (You may have little enough noise on your 5v power supply, and a pulse-length-measurement that is not as accurate as an FPGA, and so analog may be a better choice.)
EDIT:
about those rangefinders: They have a MINIMUM distance around 5-10 inches. (it will say on the datasheet). If you get closer than that, you will get false readings.
-- Marshal Horn
Does anyone know what sensors we can use? gilkeedman General Forum 3 30-01-2010 04:20
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Can anyone tell me the proper code for line sensors thelastride Programming 1 14-02-2004 13:47
Anyone using sensors??? Willum Robot Showcase 42 25-02-2003 18:57
